Go to Post It makes you wonder what sort of sick, twisted mind would do such a thing to all those innocent teams out there... - dlavery [more]
Unread 28-02-2012, 20:44
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
Solenoid not working in autonomous
is there any reason for a specific solenoid to not work in autonomous, but then be fine for teleop? don't have code right now, but any help would be appreciated
Unread 28-02-2012, 20:47
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Re: Solenoid not working in autonomous
I think if you post some pictures of your code folks may be able to help you more specifically.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 28-02-2012, 21:01
Nothing particularly unique that distinguishes Teleop from Autonomous vi's.
A Ref name misspelling could cause it to work one place, but not another.
Being set in a third vi, like Periodic Tasks, at the same time could cause conflicts.
A general code error such as setting and resetting it too fast for the eye to follow might be a cause.
No Diagnostic error messages to decypher?
Unread 29-02-2012, 07:22
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
nothing except for the Robot Drive not running fast enough, but that is always there. I'll see if i can get the code
Unread 29-02-2012, 19:24
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
here is the code. I couldn't see anything wrong with it; i hope someone can help me
Unread 29-02-2012, 20:00
So which specific solenoid isn't working the way you want it to? What do you expect it to do, and what does it do instead?
You didn't show us Teleop, which you said does work. Seeing it might give us a clue as to the problem.
[edit]The Periodic Tasks vi runs constantly, even during autonomous. It looks like the Loader solenoid is going to be set Forward every ten milliseconds, regardless of what Autonomous Independent wants it to be doing.[/edit]
Last edited by Alan Anderson : 29-02-2012 at 20:13. Reason: noticed something about the code
Unread 29-02-2012, 20:10
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
when i said teleop, i meant teleoperated mode (i put it under periodic tasks). It is the first solenoid under autonomous (the solenoid named "Loader") I think you can figure out what i want it to do by the code, but it isn't doing anything.
Unread 01-03-2012, 15:45
mtnteam mtnteam is offline
3747 - Programmer
AKA: Steven
FRC #3747 (ChaoTech)
mtnteam is an unknown quantity at this point
i think you can refer your problem to the problem i had
http://www.chiefdelphi.com/forums/sh...d.php?t=104048
Unread 01-03-2012, 21:10
NeatNit's Avatar
NeatNit NeatNit is offline
Alumni Programmer
FRC #1577 (Steampunk)
NeatNit is an unknown quantity at this point
This is happening because you are giving the solenoid a command. 100 times a second you tell it to be Forward inside Periodic. in Autonomous you tell it to go to Reverse, but then less than 1/100 of a second after that you tell it again in Periodic to go Forward, so it never had a chance to move.
You have to realize that Periodic Tasks runs all the time, even during Autonomous. Use Teleop.vi for your teleop needs, not Periodic.
A common way to update motors/actuators is to write to a global variable inside teleop or autonomous, and then read from that global variable in Periodic and update the motor accordingly.
Unread 02-03-2012, 07:55
tilky's Avatar
AKA: Ryan Thielke
FRC #3137
ok i got it now. i didn't realize that before, so i had a local variable controlling the same solenoid, which defaults in reversing the pistons, so that would make it not work.
One more question, if you copy the time cluster from the front panel of teleop and paste it into teleop and use that to find the elapsed teleop time, would that work or is Elapsed Times.vi only writing to the one in teleop?
