Go to Post Once you know where you want to go, you can decide how you want to get there. - sciguy125 [more]
Unread 28-02-2012, 21:27
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
Re: Use Gyro to turn 90 Degrees
Alright I will be testing that tomorrow. I was curious about the value range because we had the bot set up with the following code:
float angle = gyro.GetAngle() + 90;
myRobot.Drive(-0.2, -angle / 30);
The robot went straight before the "+ 90"; the -0.2 is because a negative value is actually forward on the bot.
The result when running this was that the robot would turn right at a medium rate and continue turning after passing 90 degrees.
The other result that seemed odd was that changing "/ 30" to "/ 1" caused a slower turn rate while changing it to "/ 60" caused a faster turn rate.
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
Unread 28-02-2012, 21:42
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
If you just want a simple turn, don't use myRobot.Drive, just use ArcadeDrive, like this:
#define TURN_TOLERANCE 0.5
void Turn(float angle)
    float targetHeading = gyro.GetAngle() + angle;
    while (fabs(targetHeading - gyro.GetAngle()) > TURN_TOLERANCE)
        myRobot.ArcadeDrive(0.0, (angle < 0.0)? -0.5: 0.5);
However, if you want to adjust the turn power according to how far you are from your target, then you need to use PID.
BTW, you should really fix your signs by calling myRobot->SetInvertedMotor(), you will benefit from it in the long run.
