Go to Post Remember kids, it's not about the speed of your drive train, it's how you use it - Michael Corsetto [more]
Unread 27-02-2012, 18:04
ProgrammerBlake ProgrammerBlake is offline
FRC #2977
ProgrammerBlake is an unknown quantity at this point
Watchdog or MotorSafety?
I am just wondering are we using watchdog still this year, or are we using Motor Safety this year. Sorry if this is a silly question.
Unread 27-02-2012, 18:33
Re: Watchdog or MotorSafety?
Both!
Unread 28-02-2012, 17:01
FRC #2977
Thank you Ether. I have another question then, we have motors other than drive (like shooting and picking stuff up) would those motors need the MotorSafety method and watchdog. Thanks in advance.
Unread 28-02-2012, 18:20
The User Watchdog is available but disabled by default. The Motor Safety is Enabled by default for RobotDrive objects but disabled by default for Jaguar or Victor objects.
I encourage the teams I work with to enable Motor Safety on all objects for two reasons, the first is safety and the second is it is a useful indicator that the code is not running as fast as it should be if these start tripping.
Unread 28-02-2012, 22:45
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
Remember both systems still do not account for careless mistakes such as running motors against each other or threaded while loops that update. Motorsafety/watchdog should be a backup to common sense and not the primary failsafe to errors.
Last year we lost three FP motors to our autonomous due to some very stupid* mistakes.
*A mistake becomes stupid when repeated after one has already learned from it. I forgot to document, double check and test before running in the field. The heat of competition can cause heat stress
corin.rypkema.org
WPI Class of '17
'12 Dean's List Finalist, Mentor of 706 - Cyberhawks
Unread 01-03-2012, 16:34
FRC #2977
Okay, thank you guys so much this was really helpful.
Unread 01-03-2012, 20:03
touchdownjesus4's Avatar
touchdownjesus4 touchdownjesus4 is offline
AKA: Tyler Vonderhaar
FRC #4028 (Eagle Robotics)
touchdownjesus4 is on a distinguished road
How would one go about enabling either of these for jaguars?
Unread 05-03-2012, 17:27
FRC #2977
Is either of these required, or just one, both. Sorry if this is a silly question, thanks in advance.
Unread 07-03-2012, 12:00
Neither is required. The MotorSafety is enabled by default for RobotDrive objects but not for Victor, Jaguar or Relay objects.
Unread 08-03-2012, 23:19
techkid86's Avatar
techkid86 techkid86 is offline
Magic Programer
FRC #3044 (0xBE4)
techkid86 is an unknown quantity at this point
To be honest, i would just use motor safety. if you can get both working though more power to you. my first year programing i had some bad experience with watchdog... it blew up our code cause it was running a little slow because there was a lot of it. be very careful when using it in competition, make sure the kill time limit is large enough for a little error. (also accommodate for field lagg.
"you can build a perfect machine out of imperfect parts" -Urza
