Go to Post Coming to MTV this fall: Pimp my Segway - Francis-134 [more]
Unread 27-02-2012, 19:24
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Jaguar VBus Fault
Anyone experienced that before? Anyone know of a potential cause of that problem? I presume a short. Is it recoverable, or is the Jaguar dead?
Unread 27-02-2012, 19:36
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
Re: Jaguar VBus Fault
What's your battery voltage when idle? When under load? Usually the fault is a result of a stalled motor drawing too much current, or a low battery voltage to begin with.
Unread 27-02-2012, 20:08
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
It's just one Jaguar, other two are fine. The Jaguar has an over current protection that usually resets itself, but this was persistent for a full day.
Unread 28-02-2012, 23:54
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
We're going to need some more information:
What were you doing before and leading up to the fault?
What diagnostics have been done to identify the fault? (i.e. how do you know its a vbus fault and not something else?)
PWM or CAN?
What kind of motor and mechanical load is being driven?
Matt
Matt Krass
Unread 29-02-2012, 18:28
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
PWM or CAN?
Matt
I did not witness the actual malfunction. It was driving perfectly fine during lunch (I was driving). But the period after that (may be 20-30 minutes after), one of the jaguars gave out. So today, I switched the drive motors to a good black one, but then same story as yesterday, the other jaguar blew out (not the black one, but a grey one). The gearboxes were cimple boxes and CIMs were used.
The diagnostics was done using the TI's Jaguar flasher. So it was daisy chained using CAN cables to the computer and the flashing software indicated a vbus fault. The motors were not driven by CAN, but by PWM.
Unread 02-03-2012, 19:15
David,
A Vbus fault could be caused by a bad crimp, bad breaker or improperly terminated wiring in the PD. It is simply an indication that when you draw current, the voltage drops feeding the Jag. You might get the same fault with a motor that is drawing a lot of current but not enough to throw a high current trip.
Check every inch of the wire between the PD and the Jag that is faulting looking for shorts, bad crimps, whiskers, loose hardware. Try spinning the motor by hand and see if there is a lot of resistance to your spin. It could be a bad motor, or improperly mounted motor on the transmission. If it is a drive motor, do you get the same results with the wheels off the floor?
