Go to Post Our coolant system consists of a freshman with a squirt bottle. - Holtzman [more]
Unread 29-02-2012, 13:08
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
Switch Program
Using the Honeywell Switch on the robot. What declaration do I use? And how do I get the state it is in? Do I use the DigitalIOButton to declare it and just use the Get() which returns a bool value?
Thanks in advance!
Davis
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
Unread 29-02-2012, 13:22
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: Switch Program
The DigitalIOButton class is for a button on the DriverStation (e.g. connected to the Cypress module). Are you using that? Or is your switch connected to the robot? I am assuming it's on the robot. If so, are you connected it through some digital input channel? The way to access a switch connected to a digital input channel is something like this (assuming digital input channel 1):
DigitalInput limitSwitch(1);
limitSwitch.Get();
Unread 29-02-2012, 13:23
FRC #0539 (Titans)
Re: Switch Program
Yes the switch is on the robot connected to DIO port 1 on the DSC.
FRC Team 539
Unread 13-03-2012, 00:42
synthmusic synthmusic is offline
FRC #3574
synthmusic is an unknown quantity at this point
Re: Switch Program
Not sure if this is what you are looking for, but as an example we have a switch used as a travel limit to stop a motor. It's used as follows:
DigitalInput *bBallElevatorTopLimit;
bBallElevatorTopLimit = new DigitalInput(2,2);
// if top limit clicked
if (!bBallElevatorTopLimit->Get())
the switch reports 1 when it is open and 0 when closed because we wired the switch signal to ground on the DSC.
Hopefully that helps!
