Go to Post I guess what I am trying to say is that GP is inside all of us just waiting for a chance to escape. I am sure how the virus spread. I put the blame solely on the shoulders of Chief Delphi. - Ken Loyd [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 29-02-2012, 18:30
clandes573 clandes573 is offline
FRC #0573
clandes573 is an unknown quantity at this point
polycord problems
Hello,
I'm Carrie from FRC Team 573, the Mech Warriors. We are using polycord for our pick-up system, but we've been having some trouble getting the ends to stick together. We are using 3/16" polycord, which does not seem to melt and fuse well. We're currently using ferrels, but we also want to glue the joints. Does anyone know the best glue to use and where we can get it? Thanks for the help!
Sincerely,
Carrie
FRC Team 573
Unread 29-02-2012, 18:33
Eric Yahrmatter's Avatar
Eric Yahrmatter Eric Yahrmatter is offline
FRC #0033 (Killer Bees)
Eric Yahrmatter has a spectacular aura aboutEric Yahrmatter has a spectacular aura about
Re: polycord problems
We use the heating tool from this kit to weld our belts together:
http://www.mcmaster.com/#belt-welders/=ggqtd0
Unread 29-02-2012, 18:41
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
We went with the 1/4" poly. We used a small 3" vice, put a plate in the middle. We heated the plate hot as we dared and then stuck the ends and let them fuse, letting them cool to room temp. Thus far, no breakages.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
Unread 29-02-2012, 19:41
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
How have you been trying to fuse the ends together?
We generally use a lighter to weld our polycord; if we really have to, we'll use a heat gun, but because heat guns have a wider heat output, we find that they tend to melt too much.
Melding joints together takes a little time; it can take as long as a minute to liquefy ends of just 1/4" polycord.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 29-02-2012, 20:04
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
We usually use an old soldering iron as it keeps the students away from anything involving a torch.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 29-02-2012, 20:33
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
We use a hot knife (essentially an exacto knife stuck in the end of a soldering iron, for those that don't know). They should be available at most hobby shops. Just let it heat up, stick the two ends of the polycord on opposite sides of the knife, get it all properly aligned, and slide the knife out of the way.
Unread 29-02-2012, 20:35
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Carrie,
I know you asked specifically about welding the 1/4 polycord together, but, have you ruled out completely using the little metal or plastic pieces to hold them together (McMaster-Carr)?
I asked Warren Hilldebrand (sp?) at Roch Adams about this issue in particular this year before going down this path and he assured me that they have had no problems with using the joining pieces for many years.
If you choose to go down this route and need a few pieces, yesterday?, let me know, we have some at Lamphere High School.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 29-02-2012, 20:42
VKP's Avatar
VKP VKP is offline
VKP
AKA: Vivek Paramasivam
FRC #1899 (Saints Robotics)
VKP is an unknown quantity at this point
Our team did it with a small torch and skillful hands: a mentor carefully holding the two ends in front of the torch ad pressing the ends together until the fused into one. This left a large lump of melted polycord around the fused point, so we cut off that part with a knife.
It takes practice, but you definitely don't need to spend $600 to get the results you are looking for.
Vivek
Treasurer, Senior Build Officer, Saints Robotics 1899
Seattle Olympic Regional Chairman's Award 2011
Seattle Olympic Regional Winner 2011 (Thanks 2990 & 3393)
Seattle Olympic Regional Best Website Award 2011
Unread 29-02-2012, 20:46
Jim Wilks Jim Wilks is offline
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
That's exactly right. Practice with scraps of polycord until you get the technique down to a science.
Jim
Unread 29-02-2012, 21:02
Spen.M.P.'s Avatar
Spen.M.P. Spen.M.P. is offline
FRC #3815 (Raider Robotics)
Spen.M.P. is an unknown quantity at this point
One key point to be made is that after they are gooey and stuck together, hold them together for a good 3-4 minutes and DO NOT put stress on them until at least 10 minutes after that. I know that it seems like it is a good bit of time for one belt, but it will hold and not break.
Unread 29-02-2012, 21:07
Electrical Engineer
AKA: Jim Wilks
Another good point. We keep a cup of cold water nearby. Once the joint is fused together, we douse it with cold water to ensure it is well cooled before we put any stress on it.
Jim
Unread 29-02-2012, 21:16
aspiece's Avatar
aspiece aspiece is offline
AKA: Andrew Spiece
FRC #0068 (Truck Town Thunder)
aspiece has a reputation beyond reputeaspiece has a reputation beyond reputeaspiece has a reputation beyond reputeaspiece has a reputation beyond reputeaspiece has a reputation beyond reputeaspiece has a reputation beyond reputeaspiece has a reputation beyond reputeaspiece has a reputation beyond reputeaspiece has a reputation beyond reputeaspiece has a reputation beyond reputeaspiece has a reputation beyond repute
Alright, how about a little secret from Truck Town Thunder. There are two different places we get polycord.
1. McMaster-Carr A little more choice in color. Seems to have a smooth surface.
or
2. / - Doesn't seem to have a choice other than green but the Polycord has a rough surface that help the balls move up an down.
We haven't had any problems melting either one. We have used soldering irons, heat guns. The best method we have found is using a soldering gun with a special tip that is flat. It seems to work the best that we have found. Something sort of like this: http://www.google.com/products/catal...CIkBEPMCMAE4Hg
Unread 01-03-2012, 00:30
A great point... we've left samples sit for about 10 minutes (although competition cords sit for longer) and non one on the team - student or mentor - could break them, no matter how hard they pulled.
Unread 01-03-2012, 00:53
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Please do not use a flame to weld polycord, the fumes are toxic!
Besides, using a hot air gun works better. Put the cord behind a hole in a piece of aluminum to shield it so only the ends are exposed. When it gets good and soft push it together making a round ball at the joint. Hold it in the 'L' of a piece of aluminum angle to keep it straight as it cools, then cut and sand the excess off. Never had a failure.
Good luck, and say hi to Joe and Tom for me!
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 01-03-2012, 07:14
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
We use a hot plate like you might find in a high school chemistry lab. We learned the hard way to cover the surface with aluminum foil to prevent the melted plastic from sticking to it permanently and then coking/charring. Agree with all of the other posts; in our experience we found it easiest to work with when the cord is heated to just below the smoke point of the material, allow for some amount of radial extrusion when the ends are pressed together, and give it a nice long cool-down time or accelerate the process with water. We dress the O.D. afterwards using a Dremel tool and abrasive wheel.
