Go to Post *When putting grease on anything* "The bigger the glob the better the job." - TheMagicPenguin [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 29-02-2012, 20:35
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Re: polycord problems
Carrie,
I know you asked specifically about welding the 1/4 polycord together, but, have you ruled out completely using the little metal or plastic pieces to hold them together (McMaster-Carr)?
I asked Warren Hilldebrand (sp?) at Roch Adams about this issue in particular this year before going down this path and he assured me that they have had no problems with using the joining pieces for many years.
If you choose to go down this route and need a few pieces, yesterday?, let me know, we have some at Lamphere High School.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 29-02-2012, 20:42
VKP's Avatar
VKP VKP is offline
VKP
AKA: Vivek Paramasivam
FRC #1899 (Saints Robotics)
VKP is an unknown quantity at this point
Our team did it with a small torch and skillful hands: a mentor carefully holding the two ends in front of the torch ad pressing the ends together until the fused into one. This left a large lump of melted polycord around the fused point, so we cut off that part with a knife.
It takes practice, but you definitely don't need to spend $600 to get the results you are looking for.
Vivek
Treasurer, Senior Build Officer, Saints Robotics 1899
Seattle Olympic Regional Chairman's Award 2011
Seattle Olympic Regional Winner 2011 (Thanks 2990 & 3393)
Seattle Olympic Regional Best Website Award 2011
Unread 29-02-2012, 20:46
Jim Wilks Jim Wilks is offline
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
That's exactly right. Practice with scraps of polycord until you get the technique down to a science.
Jim
Unread 29-02-2012, 21:02
Spen.M.P.'s Avatar
Spen.M.P. Spen.M.P. is offline
FRC #3815 (Raider Robotics)
Spen.M.P. is an unknown quantity at this point
One key point to be made is that after they are gooey and stuck together, hold them together for a good 3-4 minutes and DO NOT put stress on them until at least 10 minutes after that. I know that it seems like it is a good bit of time for one belt, but it will hold and not break.
Unread 29-02-2012, 21:07
Electrical Engineer
AKA: Jim Wilks
Another good point. We keep a cup of cold water nearby. Once the joint is fused together, we douse it with cold water to ensure it is well cooled before we put any stress on it.
Jim
Unread 29-02-2012, 21:16
aspiece's Avatar
aspiece aspiece is offline
AKA: Andrew Spiece
FRC #0068 (Truck Town Thunder)
aspiece has a reputation beyond reputeaspiece has a reputation beyond reputeaspiece has a reputation beyond reputeaspiece has a reputation beyond reputeaspiece has a reputation beyond reputeaspiece has a reputation beyond reputeaspiece has a reputation beyond reputeaspiece has a reputation beyond reputeaspiece has a reputation beyond reputeaspiece has a reputation beyond reputeaspiece has a reputation beyond repute
Alright, how about a little secret from Truck Town Thunder. There are two different places we get polycord.
1. McMaster-Carr A little more choice in color. Seems to have a smooth surface.
or
2. / - Doesn't seem to have a choice other than green but the Polycord has a rough surface that help the balls move up an down.
We haven't had any problems melting either one. We have used soldering irons, heat guns. The best method we have found is using a soldering gun with a special tip that is flat. It seems to work the best that we have found. Something sort of like this: http://www.google.com/products/catal...CIkBEPMCMAE4Hg
Unread 01-03-2012, 00:30
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
A great point... we've left samples sit for about 10 minutes (although competition cords sit for longer) and non one on the team - student or mentor - could break them, no matter how hard they pulled.
Unread 01-03-2012, 00:53
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Please do not use a flame to weld polycord, the fumes are toxic!
Besides, using a hot air gun works better. Put the cord behind a hole in a piece of aluminum to shield it so only the ends are exposed. When it gets good and soft push it together making a round ball at the joint. Hold it in the 'L' of a piece of aluminum angle to keep it straight as it cools, then cut and sand the excess off. Never had a failure.
Good luck, and say hi to Joe and Tom for me!
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 01-03-2012, 07:14
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
We use a hot plate like you might find in a high school chemistry lab. We learned the hard way to cover the surface with aluminum foil to prevent the melted plastic from sticking to it permanently and then coking/charring. Agree with all of the other posts; in our experience we found it easiest to work with when the cord is heated to just below the smoke point of the material, allow for some amount of radial extrusion when the ends are pressed together, and give it a nice long cool-down time or accelerate the process with water. We dress the O.D. afterwards using a Dremel tool and abrasive wheel.
Unread 01-03-2012, 14:43
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
We insert the two ends into a short piece of heatshrink of the same diameter, and then use a plastic welding tool to melt the two ends together inside the heatshrink. The plastic melts before the heatshrink burns.
Unread 04-03-2012, 16:45
atlas atlas is offline
Atlas
FRC #1817 (Llano Estacado RoboRaiders)
atlas is an unknown quantity at this point
Use a heat gun, it works much better than a soldering iron. Also try using 1/4", its easier to fuse in my opinion. Be sure to get fully melt the center of the polycord as well. And lastly, be sure not to "over-melt" the ends, if it gets to messy they will not fuse together correctly.
Hope this helps.
"Trust, but verify."
1768 >> 1817
Student >> Mentor
Unread 20-03-2012, 08:21
Countryman's Avatar
Countryman Countryman is offline
AKA: Nolan Gordon
FRC #0716 (Who'SCTEKS)
Team Role: Human Player
Countryman is an unknown quantity at this point
we use a sauntering tool and use the edges, melt the ends and then hold them together until the cool down and are tight.
Unread 02-03-2012, 09:58
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
After years of using a soldering iron with a flat tip, last night tried it with a heat gun. Worked great.
Unread 04-03-2012, 15:55
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
1640 uses the magic tool from McMaster. Perfect tool for the job. Makes nice clean joints. Key thing is to read and follow the instructions. Many are loath to do that, but only through the Zen like state of enlightenment from following the directions will you have success.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
