Go to Post It's a FIRST thing. You gots to understand. - Koko Ed [more]
Unread 28-02-2012, 00:11
Bendito's Avatar
Bendito Bendito is offline
AKA: Benjamin LaRoche
FTC #7837 (The Thunder Colts)
Bendito is an unknown quantity at this point
Re: Transmitting data to the cRIO from the Driver's station via TCP/UDP
This thread has been quite helpful. I am still somewhat stuck with an issue on the cRIO crashing when I send UDP to it. I suspect it has something to do with the buffers, but if anyone has helpful advice, I'm open to it!
File Type: zip 2012 Dashboard ProjectVisionProcessor.zip (315.3 KB, 14 views)
Unread 28-02-2012, 08:14
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
A couple of TCP and UDP tips and comments:
-A UDP packet is designed to fit in one Ethernet frame, limiting it to 1500bytes minus UDP headers. I believe a UDP header is 8 bytes, but don't quote me on that
-TCP is designed to send streams of bytes instead of packetized data. The disadvantage to this is that the sending application must explicitly manage the send buffer and force TCP to send it all of the bytes, and the receiving application must manage packet starts/ends.
-TCP is also a reliable medium, with error checking and retransmission. This is usually a bad thing if you care more about getting the data fast than getting all of it (if you miss a targeting packet, you will get another one in about 50ms, so you just ignore it).
-UDP is a better choice for this application due to the speed and packet-oriented nature.
-The UDP listener should have errors trapped and a timeout set to a fairly low number (I use 1000ms) - I use trapped errors as a source of determining if I actually should unbundle the packet and use it
-The UDP listener should exist in its own thread (While loop) throttled by nothing other than itself - There should be no waits. The UDP listener will block for new packets, and if you are behind in receiving packets then it's a bad thing.
-Send the smallest packets possible - Do all target filtering and multiple target analysis (stuff that works with arrays of targets) on the laptop, and send a single target coordinate to the robot over UDP - This keeps the packet size under the limit and non-variable.
Kettering Motorsports
Unread 28-02-2012, 08:21
I didn't run your code yet, but looking at the screenshots, it does look like you are only reading the udp data five times a second, pretty slow. But you shouldn't crash the cRIO doing that. What sort of crash is it?
Greg McKaskle
Unread 28-02-2012, 15:39
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
When you say crash - exactly what happens? If you can reproduce a crash with a simplified program, please contact National Instruments via our FRC forum. We can have application engineers look into it.
Doug Norman
Unread 28-02-2012, 20:55
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
CD,
Man, most of this stuff is over my head. Is there a simple example somewhere to show how to display a PWM channel, Joystick Input, or global variable on the Dashboard?
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 28-02-2012, 21:05
There is an example in the Tutorials that come with LabVIEW.
From the Getting Started window, look at
Tutorials -> Tutorial 7 - Integrating Examples into Robot Code
Then page down to Part 2 and it gives a step-by-step using a gyro output as an example.
Unread 28-02-2012, 22:57
Bendito's Avatar
Thank you, I fixed this, and created a much more simplified communication system. It actually works flawlessly now (even through repeated power ups/downs between robot and driverstation) I have some screenshots of it included.
The crash that occurs was happening whenever I was trying to debug the robot through running the robot program while still in labview with probes set up. It seems that when the driverstation tries to connect with the robot, it boots off labview's connection with the cRIO. A "Connection with the cRIO was lost" would appear, and there would be no way to put more code on without closing the driverstation. This was causing me to think it was crashing, and causing a lot of hair pulling in the debugging process, but was eventually figured out.
Name:	UDPReceiveRun.vi Block Diagram _2012-02-28_22-50-50.png
ID:	12157  Click image for larger version
Name:	[Dashboard Main.vi] Block Diagram on 2012 Dashboard ProjectVisionPro.png
Unread 29-02-2012, 06:36
marccenter's Avatar
Question Re: Transmitting data to the cRIO from the Driver's station via TCP/UDP
Thanks Mark for pointing me to the right section. One observation and one question remains.
Observation - It may be implied or understood, however, in order to have the Dashboard Main.vi become updated with the changes shown in the tutorial I found myself creating my own dashboard project on the classmate and then manually moving the 3 files created by the dashboard project (C:\Users\developer\documents\Labview Data\builds|FRC Dashboard Project|FRC PC Dashboard) to the C:\Program Files\FRCDashboard subdirectory in order for the classmate to find the new Dashboard Main.vi (did I rename the two original files in the directory late last night before copying?).
Question: I am trying to extend the example to multiple pieces of data rather than just one by trying to use the bundle function in the Dashboard Main.vi function but it doesn't seem to take it. I was able to bundle, flatten to string and input this to the Driver station Set User Data HI function inside my robot project code. Should I be able to unpack this in my new dashboard project or is the Data Hi function simplistic?
Marc Center
Unread 29-02-2012, 09:01
You can certainly do what you are suggesting. When you do the "unflatten" operation in the Dashboard, you need to show it an example of the data type you want it to create. That means you need either a bundle constant that matches the arrangement of the bundle you created in the robot project, or a typedef that you can share between the robot and dashboard projects so the robot code can do a bundle by name instead of just bundling raw data.
Unread 29-02-2012, 09:05
Copying the Dashboard files to FRC Dashboard works, you also have the options of changing the build destination to FRC Dashboard so it always gets put there when you build, or changing the Driver Station .ini file to point to your dashboard location.
Here is an example of some quick Dashboard diagnostics looked at from both the robot and the PC side of things. This is slapped together, so take it as development code. The elements are in the order they were added to the cluster on the robot side. I recreate an indicator "358 Custom data" whenever I add or remove elements, then copy that to the Dashboard side to define the order/types of elements in the cluster.
In the final robot I'd create a TypeDef to define each data element. That gives everything a name making it easier to digest and clearer to work with.
ID:	12161  Click image for larger version
Unread 29-02-2012, 19:34
marccenter's Avatar
Smile Re: Transmitting data to the cRIO from the Driver's station via TCP/UDP
Alan and Mark,
Alan - Thanks for commenting. I understand what you are saying, just need to fumble my way through Labview to make it work.
Mark - Jackpot! That's exactly the example I was looking to find. Now, time to fight with Labview again to make it work. Is there a way to bookmark/highlight that example in our documentation - great job!
BTW, can you point to an example about the 358 Custom Data vi object? This is a new function for me to work with. Mine is not shaded pink yet.
Marc Center
Unread 29-02-2012, 19:53
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
When you have a cluster (like you would use for custom dashboard data), you can right click on it and choose Create->Indicator. You can then copy/paste this indicator to other VIs (like your dashboard project) and use it there (you can change it back to a constant, if you need). It's not really a function, per se, but it's a way to make sure datatypes stay synced between projects.
Unread 29-02-2012, 20:55
marccenter's Avatar
Phil Lopreiato,
THanks for the tip - very helpful for folks like me struggling their way through Labview- especially the copy and paste of the Indicator.
Marc Center
Unread 29-02-2012, 23:51
marccenter's Avatar
Mark's 358 Custom Data Indicator looks different than mine -- what did he do differently? I can't seem to select the one in the menu. I selected an indicator but his has bubbles?? Does he have some kind of "Mr Bubbles special arrangement"?
Name:	FRC 3548 29Feb12.png
Marc Center
Unread 01-03-2012, 20:56
Right-click on the indicator and un-check "View as icon"
Or in my case, I un-checked the Tools->Options->Block Diagrams->General->Place front panel terminals as icons.
