Go to Post We can still do better, even if we've come a long way. - cadandcookies [more]
Unread 29-02-2012, 17:35
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
FRC2016 Mighty Monkey Wrenches 2012 Robot Video
New Robot Video!
http://www.youtube.com/watch?v=uV9fUUSqYaE
Note: Bridge crossing arm was removed before bagging and video.
The specs:
6 motor drive - 8wd with 6" wheels geared at 12ft/sec.
2 Fisher Price motors for front roller and belt.
2 RS-775 motors for Shooter w. a 3.75:1 gear ratio.
Max distance on shooter - 45 feet.
This robot will be competing at Hatboro-Horsham, Rutgers and NYC Regional.
Hoping for the MAR championships and St. Louis.
Good luck everyone and see you on the field.
(Btw: If you watch the video, we fixed the bumpers.)
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 29-02-2012, 18:08
electron's Avatar
electron electron is offline
Former Team Overdrive member
AKA: Joseph
FTC #2753 (Team Overdrive)
electron is just really niceelectron is just really niceelectron is just really niceelectron is just really nice
Re: FRC2016 Mighty Monkey Wrenches 2012 Robot Video
First!
Sorry, Tyler, it had to be done.
I'm noticing a few trends from previous years:
1. 6 motor drive train (why the obsession with pushing power? )
2. Blue lights
3. Awesome
I never saw the hood over your shooter adjust its angle, but it does look like it can. Is this the case?
Also, I'm assuming you are planing to put the bridge pusher back on, or was it removed for something even cooler?
Looks great, good luck this year!
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
I may be one of the few people that has moved from FRC to FTC, and enjoyed it
Unread 29-02-2012, 18:11
Lowfategg's Avatar
AKA: Tyler Moser
Originally Posted by electron View Post
First!
2. Blue lights
3. Awesome
The "hood" is a manually adjustable wedge. We change motor RPM and use a high precision encoder to adjust shooting distance.
Bridge lowering arm is on in the robot picture. It sits within the intake mouth.
Unread 29-02-2012, 21:01
Damiaen_Florian's Avatar
Damiaen_Florian Damiaen_Florian is offline
Do It Until You Can't Get It Wrong
FRC #0195 (The Cyber Knights)
Damiaen_Florian is a name known to allDamiaen_Florian is a name known to allDamiaen_Florian is a name known to allDamiaen_Florian is a name known to allDamiaen_Florian is a name known to allDamiaen_Florian is a name known to all
How are you tipping the bridge? I don't really notice any mechanism on it for doing so
Unread 29-02-2012, 21:06
Lowfategg's Avatar
AKA: Tyler Moser
It was taken off before bagging and the video for refinement. You can see it in the photo of the robot in the intake opening.
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Well...
Anyway, another awesome robot, 2016. Can't wait to compete with you this season!
Unread 29-02-2012, 21:12
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Awesome looking robot. Simple and extremely effective.
Very curious how you feed the shooter and get the balls to line up so compactly. Care to elaborate?
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 29-02-2012, 21:16
Lowfategg's Avatar
AKA: Tyler Moser
There is a top feed roller that stops the balls before the shooter. The belts of the elevator just spin against the balls as they stack up against each other.
Unread 29-02-2012, 21:34
Lowfategg's Avatar
AKA: Tyler Moser
Originally Posted by aspiece View Post
I have to point something out:
From the FRC Q and A:
"Per [R35], team numbers must be clearly visible. This means that they may not be inverted, obscured, fragmented, upside down, etc."
So, according to this answer, you cannot split your numbers.
Read the description, then watch the video again.
Unread 29-02-2012, 21:59
Thumbs up Re: FRC2016 Mighty Monkey Wrenches 2012 Robot Video
Real nice! Should put on quite a show at Hatboro.
See you guys on Saturday! Good luck.
Unread 29-02-2012, 23:11
ks_mumupsi ks_mumupsi is offline
Drive Coach...
AKA: Kinsuk Shah
None #2016
ks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud of
thanks for all the comments..
tyler has answered all the questions so i dont even need to be here. I will just let him virtual coach from WPI also.. hahaha.
looking forward to getting it on the field against other bots and seeing its potential.
I will answer the 6 motor question also, we will never give up 6 motors on the drive ever again, that gearbox and train is amazing and takes the need of two speed out of the equation..
Other than that good luck guys...
Team 56 2000-2007 (Student/Vol.)
Team 2016 2008 - ??? (Mentor)
Unread 01-03-2012, 00:01
SciBorg Dave SciBorg Dave is offline
AKA: Dave Tharp
FRC #5920 (VIKotics)
SciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to behold
Nice finished product. It was fun to spend some time with 2016.
Uncle Dave 4061
Unread 01-03-2012, 10:16
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
I've never quite understood the whole 6 motor single speed thing. Otherwise though it's a very clean solid looking robot. Should be quite the contender
Mentor 2415
Unread 01-03-2012, 11:46
Drive Coach...
AKA: Kinsuk Shah
None #2016
heh... if you wanna see more proof of solid drive train, look up 2010 finals match 2 for NJ regional. it is one of the most intense matches I have ever been a part of from a driving standpoint...
also theres nothing better than being able to push a defending robot across the field sideways
Unread 01-03-2012, 11:54
Hallry's Avatar
Dare to be FIRST
AKA: Ryan Hall
Ah, the legendary ball return penalty of the 2010 NJ Regional
