Go to Post Way to think outside the box...or circle..or triangle. - Barry Bonzack [more]
Unread 29-02-2012, 22:30
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
Multiple Auto modes
Hi I have two different auto modes one for the middle hoop and one for the middle hoops. This is my first year with auto and this is my first year using labview. Could someone please help me with codeing how to recognize a on off switch on a digital i/o on the digital sidecar and how you implement it in code? Sorry if there is another thread on this topic but I've tried looking for it, I've googled it but no luck. Right now before I put the robot in the bag I put two of the tetrix on/off switches on digital ports 1 and 2. Any help would be greatly appreciated.
-Garten Haeska
Team 2861
Minnesota 10,000 Lakes Regional
"Sometimes the questions are
complicated but the answers are simple."
- Dr. Seuss
Unread 29-02-2012, 22:54
MotorHead's Avatar
MotorHead MotorHead is offline
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
MotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to behold
Re: Multiple Auto modes
Another way of doing this is to use the digital input of the driver station program. Goto the I/O on DS program and you can set channels 1-8 are true or false. Think of it as a software version of hardware switches. These switches can then be read from your program.
Look in the default framework program in the Autonomous Independent. There is already a vi in there that checks the status of the switches. Attached is a portion of code that will take these inputs and convert them to a number. Wire this to a case structure to run the auto program you want.
Jeff Beltramo
Team #1922
Concord, New Hampshire
Unread 01-03-2012, 05:24
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
a good thing to use also is the axis 3 on the joysticks (the knob at its base) if you run out of driver station input
But who would run out? (us)
