Laggy camera
Hi I have connected my camera directly to the router and before I would get decent video but I started to add a bunch of senors to my dashboard and now I get really laggy video. How could I fix this.
Re: Laggy camera
If the problem began after you added sensors (sensor readouts?) to the dashboard, you could try removing some readouts to speed up the dashboard and reduce video lag. A faster computer might be able to handle more sensor readouts without increasing video latency.
Re: Laggy camera
Aren't we only allowed to use the classmate for the comp. And well I can remove any senors since they are vital for our aiming and balancing.
Re: Laggy camera
You are permitted to use any laptop.
Re: Laggy camera
Are the sensors and whatever is refresing the video feed in a loop together? If this is the case (Pure speculation, I havent looked at an FRC robot all year much less Dashboard code) then you are probably waiting for other operations to finish that take longer than refreshing the camera feed. Put them in seperate loops and they will work in (psuedo)parrallel.
