Go to Post Legos rock! - Kyle Love [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Unread 03-01-2012, 11:13 AM
Re: Best way to drive straight using a gyro?
Originally Posted by ProjectZero View Post
protected double returnPIDInput() {
// Return your input value for the PID loop
// e.g. a sensor, like a potentiometer:
// yourPot.getAverageVoltage() / kYourMaxVoltage;
return gyro.getAngle();
protected void usePIDOutput(double output) {
// Use output to drive your system, like a motor
// e.g. yourMotor.set(output);
if (gyro.getAngle() > 1)
Not like a potentiometer. See bolded portions below:
 * Return the actual angle in degrees that the robot is currently facing.
 * The angle is based on the current accumulator value corrected by the oversampling rate, the
 * gyro type and the A/D calibration values.
 * The angle is continuous, that is can go beyond 360 degrees. This make algorithms that wouldn't
 * want to see a discontinuity in the gyro output as it sweeps past 0 on the second time around.
 * @return the current heading of the robot in degrees. This heading is based on integration
 * of the returned rate from the gyro.
float Gyro::GetAngle( void )
