Go to Post Mentors are the guardrails: Show the students how to do what they need to do, Step back and let the students do what they need to do, Nudge them back on course when they need a nudge, Insist, when necessary, that no one tries to juggle the chainsaws - gblake [more]
Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Unread 28-02-2012, 16:10
ProjectZero ProjectZero is offline
FRC #4276 (Vikings Robotics)
ProjectZero is an unknown quantity at this point
Help driving straight using PID and a Gyro.
Hi all,
Working on coding our robot to be able to drive straight using a gyroscope. The gyroscope initializes at the beginning of the map, getting it's initial heading. Now, I want the robot to at the press of a button be able to turn back to that orientation. I think I've finally structured the code below correctly. Questions:
1. Am I correct in assuming that when I enable PID in my DriveStraight command by writing enable(); that the robot will start doing what is written in the usePidOutput method?
2. What will the bounds of the "output" variable be? I know it's a finely tuned variable of the error between my gyro heading and my desired heading of 0, but I don't know if I can plug it into my motors or not.
I apologize in advance if there's a topic that answers this question. If that's the case, please just link me.Thanks in advance for your help.
SUBSYSTEM CODE
package edu.wpi.first.berserker.subsystems
import edu.wpi.first.wpilibj.command.PIDsubsystem;
public class DriveTrain extends PIDSubsystem (
private static final double Kp = 3;
private static final double Ki = .2;
private static final double Kd = .1;
private Robotdrive drive = new RobotDrive(Robotmap.leftMotor, Robotmap.rightmotor);
private Gyro newgyro = new Gyro(Robotmap.gyro);
private DriveTrain() {
super ("DriveTrain", Kp, Ki, Kd);
public void initDefaultCommand() {
setDefaultCommand(new DrivewithJoysticks());
protected double returnPID(){
return gyro.pidGet();
protected void usePIDOutput(double outpout) {
//Not certain what needs to go here.
COMMAND CODE
package edu.wpi.first.berserker.commands;
public class DriveStraight extends CommandBase (
double setPoint;
public DriveStraight(double setpoint) {
requires(drivetrain);
this.setpoint = setpoint;
protected void initialize() {
drivetrain.setSetpoint(setpoint);
drivetrain.enable();
protected void execute() {
protected boolean isFinished() {
return Math.abs(drivetrain.getPosition() - setpoint <.02);
protected void end() {
drivetrain.disable();
protected void interrupted() {
Unread 01-03-2012, 10:44
Re: Best way to drive straight using a gyro?
This is the code as updated at our last meeting before our regional. We'd really like to get an idea of how well it'd work before we get there:
package edu.wpi.first.ReboundRumble.subsystems;
mport edu.wpi.first.ReboundRumble.OI;
import edu.wpi.first.ReboundRumble.RobotMap;
import edu.wpi.first.ReboundRumble.commands.DriveWithJoys ticks;
import edu.wpi.first.wpilibj.Gyro;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.command.PIDSubsystem;
import edu.wpi.first.ReboundRumble.commands.CommandBase;
* @author Developer
public class DriveSystem extends PIDSubsystem {
private static final double Ki = 0.2;
private static final double Kd = 0.1;
RobotDrive drive= new RobotDrive(RobotMap.LeftDrive, RobotMap.RightDrive);
Gyro gyro = new Gyro(RobotMap.gyroPort);
// Initialize your subsystem here
public DriveSystem() {
super("DriveSystem", Kp, Ki, Kd);
setSetpoint(0);
// Use these to get going:
// setSetpoint() - Sets where the PID controller should move the system
// to
// enable() - Enables the PID controller.
// Set the default command for a subsystem here.
//setDefaultCommand(new MySpecialCommand());
setDefaultCommand(new DriveWithJoysticks());
protected double returnPIDInput() {
// Return your input value for the PID loop
// e.g. a sensor, like a potentiometer:
// yourPot.getAverageVoltage() / kYourMaxVoltage;
return gyro.getAngle();
protected void usePIDOutput(double output) {
// Use output to drive your system, like a motor
// e.g. yourMotor.set(output);
if (gyro.getAngle() > 1) {
DriveReg(0, output);
if (gyro.getAngle() < -1){
DriveReg(output, 0);
drive.tankDrive(.5,.5);
Unread 01-03-2012, 11:13
Not like a potentiometer. See bolded portions below:
 * Return the actual angle in degrees that the robot is currently facing.
 * The angle is based on the current accumulator value corrected by the oversampling rate, the
 * gyro type and the A/D calibration values.
 * The angle is continuous, that is can go beyond 360 degrees. This make algorithms that wouldn't
 * want to see a discontinuity in the gyro output as it sweeps past 0 on the second time around.
 * @return the current heading of the robot in degrees. This heading is based on integration
 * of the returned rate from the gyro.
float Gyro::GetAngle( void )
