Go to Post There is beauty in pure simplicity. - artdutra04 [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 01-03-2012, 03:13
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
CowScout 2012 Data Entry Form
Here's a preview of the data CowScout will collect this season!
http://i.imgur.com/6Zfcy.png
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 01-03-2012, 07:27
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Re: CowScout 2012 Data Entry Form
Looks like it covers just about everything. Just a couple of quick questions; when will CowScout be live, and can you set up a "Test Event". Also I would suggest making a printable version of the sheet for those teams that wish to paper scout and then use CowScout as their database.
Thanks for all the work you guys have put into this so far. I am hoping to have the team use it this year at NYC and CT.
Unread 01-03-2012, 12:17
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
We're just finishing up some of the last details. Should be up sometime today along with a printable version of the sheet.
Team 1538 / The Holy Cows, 2005-2016
Unread 01-03-2012, 12:27
AKA: Justin Foss
Awesome, thanks for the update Jon
Unread 01-03-2012, 13:04
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
Once you've set up an acount, is there a way to see the scouting sheet? Or even print a copy out?
Unread 01-03-2012, 22:25
Nolo's Avatar
Nolo Nolo is offline
FRC #2481
Nolo is an unknown quantity at this point
Is there a way to delete a selection list? Everything else looks great!
Team 2481
Roboteers
Unread 01-03-2012, 22:35
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Looks clear and intuitive.
My piece of constructive criticism: The spacing on those buttons seems a bit obnoxious (mostly because many of us will be filling these out with laptops using touch pads), maybe the final sheet can squish them up closer to each other?
I will be using the system regardless of that minor detail
Unread 01-03-2012, 22:39
Hadi379's Avatar
FRC #0379
Under Autonomous Mode, you have "Tipped Co-op Bridge", but after seeing 179's Autonomous, its possible to tip your own alliance bridge as well. Also, should there be anything about whether a team uses the bump, ramp, or both to traverse the field during teleop?
[IMG] code is Off
