Go to Post You can never have enough teamwork. - Koko Ed [more]
Unread 20-02-2012, 11:07
Re: Shooter burning motors...but why?
Originally Posted by matthewdenny View Post
Could anyone point me in the direction to find the motor specs documentation? A link would be great.
Originally Posted by squirrel View Post
or here:
http://www.chiefdelphi.com/media/papers/2432
Unread 20-02-2012, 12:37
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Running at anything more than 50% of stall torque amps is a cause for concern. Or possibly even less.
You are right. I was actually thinking of 30% stall torque amps which would be about 70% free speed.
Unread 20-02-2012, 12:45
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
We burned up a couple because we blocked the air vents. Good ole CD search turned that one up quick. We are mounting our motors in the sideplate of our shooter, a couple holes in the sideplate inline with the vents and problem solved.
At least the banebots aren't as much as the tetrix motors from last year.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 25-02-2012, 19:34
matthewdenny's Avatar
matthewdenny matthewdenny is online now
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Turns out we were covering he vents. Works great now. Thanks everyone.
Unread 26-02-2012, 16:43
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
If you have time to pick up some hobby motor heat sinks from towerhobbies.com, there are black ones that fit the 550 series diameter perfectly. I think we had to cut them to fit. http://www3.towerhobbies.com/cgi-bin...&I=LXNAB1&P=ML
Pretty much all failures with BaneBot motors are attributable to excessive heat buildup. I am working on an FRC MTBF plots for the BaneBots using our motors, understanding there are various uses and setups. If I have time, I'd like to put a call for data from the community.
Another thing to watch out for is case shorts. Once the motors heat up too much, the enamel used for sealing the shaft melts off and then the current is allowed to flow from each terminal to the case of the motor (and then your robot). Make sure you consider mounting with nylon screws and washers or other non-conductive hardware. Please note that a case short does not indicate the motor is gone. We've run case short motors for a reasonably long duration before they finally failed.
Unread 26-02-2012, 17:40
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Plastic mounting screws are only half the battle to having a fully electrically-isolated motor. You also have to isolate the motor output shaft via either plastic gears or timing belts.
Art Dutra IV
世上无难事,只怕有心人.
Unread 27-02-2012, 07:18
protoserge's Avatar
This is true. Thanks for the addition
Unread 27-02-2012, 08:43
drwisley's Avatar
drwisley drwisley is offline
FRC Coach
AKA: Dave
FRC #1756 (Argos)
drwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant future
Or an isolated coupling.
Unread 27-02-2012, 15:33
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
We lost one of the RS-550 motors on our shooter, too. We have two driving a single shaft, and one of them started making funny buzzing noises. Upon close examination, we found that the plastic fan had become detached from the motor shaft, and was not providing full cooling. We don't know if this was the root cause of the overheating, or a symptom.
I should note that this was after several hours of intermittent running, calibrating the shooter speed to distance from basket, for our vision based shooter control. We replaced the motor, and placed a couple victor fans so they blow continuously over the exterior of the motor cases. Our motors stay cool now. Got to love forced convection.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 01-03-2012, 05:33
protoserge's Avatar
Yes, the root cause is overheating. I assume you are using a cimulator. If so, you should mill the face of the mounts down to allow air to flow into the motor intakes.
A good idea is here:
http://www.chiefdelphi.com/forums/sh...d.php?t=101996
Unread 01-03-2012, 10:23
J.Warsoff's Avatar
J.Warsoff J.Warsoff is offline
BECAUSE SCIENCE
AKA: Jared Warsoff
FRC #1676 (The Pascack PI-oneers)
J.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond repute
We had a similar problem with our BaneBots for the shooter. They would get hot very fast due to frequent running at high speeds. I came up with a solution using fans. I found a box full the small fans that they use on the Victors and only had to use 2 of them. I extended to the wires to they could reach down from the top of the robot where the shooter is to where the electrical board. Since the fans on their own count as electrical loads, I had to wire them to Spikes wired to the PDB. As for mounting the fans, all I did was use velcro strips (looped strip on side of fan, hooked strip under the motor) to keep the fans in a position where they blow up and against the side of the motors.
THe fans have worked wonders for the motors. They will either stay relatively cool during extended use, or will cool in under a minute after heating up. Weight was no issue at all, being that both fans and Spikes, along with the wires, weighed in at only 0.4 lbs in total.
This may be a good solution to overheating motors. I'll put some pictures up soon as a reference.
"I reject your reality, and substitute my own!" -Adam Savage
Check me out on Twitter or Facebook
Acoustical Engineering & Music major at the University of Hartford / Hartt School of Music Class of 2017
Unread 01-03-2012, 11:58
High speeds is not the problem. High loads is.
Unread 01-03-2012, 21:37
J.Warsoff's Avatar
BECAUSE SCIENCE
AKA: Jared Warsoff
I stand corrected. The load and the gear ratio combined can also cause problems, I believe.
