Go to Post Well, air conditioners when pointed inside the house make it cooler. So I figure if EVERYONE turns their air conditioners on full blast and just point them out the window, we should more or less get rid of this "warming" nonsense. - Mike [more]
Unread 02-03-2012, 07:58
jeremy5561 jeremy5561 is offline
FRC #0919
jeremy5561 is an unknown quantity at this point
Kinect Gesture Programming
The default server code lets the kinect sense the angle from shoulder to wrist. This is mapped to the Y-axis of the joystick.
I'm trying to get the kinect to recognize a gesture in which the driver brings his arms forward. Is this motion in the YZ plane or XZ plane because when I try doing the YZ plane it doens't work properly, and there is no code to measure angle in the XZ plane.
Unread 03-03-2012, 08:53
Re: Kinect Gesture Programming
I'm pretty sure the coordinate space has Z being toward-and-away from the Kinect, X being side-to-side, and Y being up/down. Make sure that some late code isn't zero-ing the axis if the arm is not in a particular plane -- as a safety mechanism.
Greg McKaskle
