Go to Post I know the code works, I wrote it! It must be a hardware problem. - buss [more]
Unread 05-01-2003, 21:47
Rusted_Grail Rusted_Grail is offline
Rusted_Grail is an unknown quantity at this point
On the Ramp
What is considered penatrating the wire mesh? I heard something about seeing it through the bottom at kick off. Does that mean you can go into it as deep as but no deeper than the bottom level of wires?
Unread 05-01-2003, 23:07
carlye carlye is offline
#0973 (Greyhound Roevolutionary Robotics)
carlye is an unknown quantity at this point
it can penetrate no more than 1/8 or 1/16 inch or something like that.
Unread 06-01-2003, 07:18
Rules state that there can be no projection beyond the bottom layer of the mesh.
Unread 06-01-2003, 08:34
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
The diameter of the mesh is 1/8" so you have technically can have 1/4" protrusuions but be careful as materials can give a little under the weight of your bot and then get past the bottom of the mesh. If noticed, DQ, if not, an honest mistake that can be construed as 'cheating' the rules.
Unread 06-01-2003, 08:37
JTH JTH is offline
#1447 (Panther Robotics)
JTH is an unknown quantity at this point
Send a message via AIM to JTH
I believe the wire is .118" diameter and is made of 2 crossed wires, so I assume that the tread cannot be able to penetrate further than .236" while the robot's weight is on top of the wire grid .
However, I don't see anything on the inspection sheet to check this, and on the field it would be virutally impossible to tell the difference if it extended further a little bit, so unless it is immediately obvious that a robot could violate it, it would be up to gracious professionalism of teams to check their robot for themselves.
Unread 06-01-2003, 09:18
Melancholy's Avatar
Melancholy Melancholy is offline
mmm... robots...
#0263 (Aftershock)
Melancholy is an unknown quantity at this point
Send a message via AIM to Melancholy
I think this was really only made so teams dont give their robots spikes for traction, or any devise to actually hook onto the mesh for brakes. As long as you don't have something that is purposely using the mesh in that way, then I think it's safe to say there won't be a problem.
*Kimberly*
Melancholy <3 Chubtoad
Unread 06-01-2003, 09:55
UCGL_Guy's Avatar
UCGL_Guy UCGL_Guy is offline
AKA: Ken YorK
None #0476 (Wildcats)
UCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to all
Send a message via AIM to UCGL_Guy
Mesh
2 things
1 the mesh is spot welded so if a bot had claws or hooks the mesh welds could be broken in heavy interaction. also do not count on it being exactly the dimensions described and the weld actually decreases the diameter of each wire, get a set of calipers and measure. I expect tech inspections to be stricter on the rules after last years fiasco. FIRST listened about us wanting rules with little leeway.
2 Kimberly you are welcome to join our team as an honorary ADIDARON - ADIRAR has been our team name/robot for the last three years now. We will build Addy 4 this year.
KY Mentor team 476 Adidarons
Unread 06-01-2003, 10:50
JTH JTH is offline
Another thing to note about the ramp: The mesh is supported with 2x6(?) supports about 12" apart, arranged with the planks going up the ramp.
Under a load of about 200 pounds with a contact area of about one size 9 shoe (in other words, under my weight, while standing on one leg), the mesh sank in about 1/2"-3/4". Bouncing on the mesh, I probably moved as much as 2" up and down without my foot leaving the mesh.
I doubt that will be really significant, but something to keep in mind, in case anyone had features that extend low to the ground.
4th Annual Ramp Riot: Team List Update OZ_341 Off-Season Events 14 09-10-2003 15:25
Q&A Discuss: How long is the bump from the ramp to the top? CD47-Bot Extra Discussion 1 11-01-2003 09:48
blocking the ramp Jacqui Sutton General Forum 3 07-01-2003 09:02
Pulling robot off ramp legal? archiver 2000 2 24-06-2002 00:14
Technical question about ramp balancing archiver 2001 5 23-06-2002 22:29
