Go to Post FIRST is an organization where you leave lasting impressions on people you don't even know. - rtfgnow [more]
Unread 01-03-2012, 16:59
Morphine Kevin Morphine Kevin is offline
FRC #4090 (RebTeks)
Morphine Kevin is an unknown quantity at this point
Dallas machine shop
At the competition we heard that there will be a machine shop set up. Are there any details as to what tools the machine shop will have? Drill press? Lathe? Saws? ETC...?
Unread 01-03-2012, 17:04
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Re: Dallas machine shop
NASA's machine shop has all of the above...But I believe they use them not you. so you kind of drop the parts off?
They did some awesome on-the-spot weld work for us last year.
Unread 01-03-2012, 17:09
45Auto's Avatar
45Auto 45Auto is offline
FRC #2992
45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future
NASA has a semi-trailer with all the basic machine tools in it (lathe, mill, bandsaw, TIG welder, etc).
As animenerdjohn said, you don't touch the machines. You drop your parts off with a drawing or sketch of what you need done. They will machine them for you on a first-come first-served basis.
2007 - Rookie All Star - Bayou Regional (1858 - Tyborgs)
2009 - Rookie All Star - Bayou Regional (2992 -Prometheus)
2010 - Champions - Bayou Regional (2992 -Prometheus)
2012 - Finalist - Bayou Regional (2992 - Prometheus)
team2992.com/design.php
Unread 01-03-2012, 17:12
Also keep in mind their limitations...
Our good friends 1296 dropped off a destroyed swerve module one time. NASA told them not to even expect it back the same day.
Id suggest only using them in an emergency - try to do as much as you can on your own.
Unread 01-03-2012, 20:19
DonRotolo's Avatar
Back to humble
FRC #0832
Oh, and you must supply the raw materials. They don't have any.
Unread 01-03-2012, 22:22
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
... which they fixed in a few hours - unbelievable skills!
Unread 02-03-2012, 01:51
They did do a good job with that.
Unread 02-03-2012, 08:32
farmersvilleRob's Avatar
farmersvilleRob farmersvilleRob is offline
FRC #4084
farmersvilleRob is infamous around these parts
Do we have to bring our own aluminum stock then?
Unread 02-03-2012, 10:14
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
better to bring your own metal - they may have some small things but in general they do not have stock
HTH
Unread 02-03-2012, 14:57
FRC #4084
Where can I buy stock then? I know I can get some through our machine shop, but let's say I have a piece that's 5"x5"x5" and needs machining.
Unread 02-03-2012, 15:20
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
McMaster-Carr or OnlineMetals.com are two possible places to order almost any kind of stock.
// Is the 5"x5"x5" piece a solid bar? It will probably take hours for the machine shop at a competition to make if there is any significant weight reduction. Generally the competition machine shops only have a manual mill and lathe, along with a variety of other smaller tools like a drill press, band saw, etc.
Art Dutra IV
世上无难事,只怕有心人.
Unread 02-03-2012, 15:38
FRC #4084
It was just hypothetical. I just wanted a measure on the abilities of the shop. So maual pieces smaller than probably a 4" cubed inches of volume is the most ideal. Anything else, you would rather bring copies or if this is a newly needed part at competition, make sure you use your engineer brains to make the design smaller with the same functions
