Go to Post 99.9999% of the FIRSTers are really nice - Denman [more]
Unread 02-03-2012, 12:25
shai's Avatar
shai shai is offline
Team Captain
FRC #3083 (Artemis)
shai has a spectacular aura aboutshai has a spectacular aura aboutshai has a spectacular aura about
cRio out of memory
Hello all,
When trying to deploy the code to the cRIO it ends up with a "Memory is Full" error immediately after trying to deploy "Robot Main", at about 2% free memory.
I see no reason for our code to take up all the available memory.
Thank you for your help.
Shai
Unread 02-03-2012, 14:59
robokiller robokiller is offline
AKA: Jaxon Weis
FRC #2757 (B.A.D.)
robokiller is an unknown quantity at this point
Re: cRio out of memory
I would like to see some code before I can tell you a solution.
but are you using a camera because if you are not freeing the images it could kill memory pretty fast.
-- Jaxon Weis
Unread 02-03-2012, 15:09
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Another possibility is that your code is saving images or log files to the cRio's internal storage and you've filled it all up, but I think RoboKiller's is more likely.
Unread 02-03-2012, 16:17
mercer13 mercer13 is offline
FRC #2614
mercer13 is an unknown quantity at this point
We had this problem with an 8 slot cRIO because the new cRIO has more storage than previous years and the new image is larger than previous ones. So if you have a 4 card cRIO and not using it I would suggest trying that.
Unread 02-03-2012, 16:34
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
Format the C-RIO using the C-RIO Imaging tool 2012 provided with the Labview installation. This will clear out the data on the C-RIO, should free the space up for your code to deploy.
"A team back in training !"
