Go to Post It sounded like a good idea, and then I thought about it. :-/ - Wetzel [more]
Unread 02-03-2012, 15:19
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Week 1 lessons learned: balancing strategy
I've been watching the KC and Alamo regionals streaming today and have seen many attempts to balance a bridge with two robots, and some successes. Many of those attempts end up with a flipped robot. I hope other teams are watching as well, and will think hard about their balancing strategy.
What works: Drive onto the bridge. Tip it towards the other robot. Allow the other robot to push you onto the bridge and do the backwards scoot to do the final balance.
How to flip over the other robot: Drive onto the bridge. Tip it towards the other robot. Allow the other robot to drive partially onto the bridge, and back away from it. Attempt to balance the bridge yourself.
This second method nearly always results in both robots fighting each other for control of the balancing. Sooner or later one of them ends up partially off the bridge when the other is on the far end, flipping the one on the downhill side.
DON'T be the team that flips anyone who tries to balance with them. Please.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 02-03-2012, 15:25
wilhitern1's Avatar
wilhitern1 wilhitern1 is offline
Sr. Systems Analyst / BRM
AKA: Neal Wilhite
FRC #1225 (Gorillas)
wilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to allwilhitern1 is a name known to all
Re: Week 1 lessons learned: balancing strategy
Our problem at the moment is that we have questionable traction (we're working to improve it). Pushing another robot up the bridge seems unlikely for the time being... We expect to be able to get on the bridge without help however.
Unread 02-03-2012, 15:26
GCentola's Avatar
GCentola GCentola is offline
Strategical Tactitian
AKA: Garrick
no team (SparX)
GCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud of
Another thing I've noticed is that teams arent allowing enough time. The bridges seem to be last-second thoughts, and often dont turn out successfully.
On the cooportition bridge, it doesn't appear that there is any logical plan for approaching it. Are alliances discussing it pre-match? It would seem as if some sort of pre-planned process would help balance (as you said, two robots trying to adjust for each other just makes it wobble back and forth)
GO SparX on 3!!!!!
Check us out at:
http://www.gosparx.org
http://www.facebook.com/SparX1126
I Love Two Pencil Designs!
Unread 02-03-2012, 15:33
pandamonium's Avatar
pandamonium pandamonium is offline
FRC #1836 (Milken Knights)
pandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond repute
Why are some robots spending the entire match trying to pick up balls or shoot and miss a hand full of times but then never have time for the bridge? They could spend the majority of the match focusing on the bridge. I think it is important to be realistic with the strengths and weaknesses of your robot. 20 points seems to be enough to win the majority of qualification matches...
P.S. I would love to see 1126 and 1511 on a cooportition bridge together next weekend.
Unread 02-03-2012, 15:49
GCentola's Avatar
AKA: Garrick
no team (SparX)
Same! We are looking forward to FLR! You guys definitely have a cool robot! If this happens, i'm sure we will know what to do after reading this thread.
GO SparX on 3!!!!!
Check us out at:
Unread 02-03-2012, 15:55
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Right now I'm feeling really good about making our robot have a very high traction drive system. There seem to be a lot of teams who are slipping all around the bridge and are completely unable to pull off a balance. I would be surprised to see many of these teams in eliminations.
Unread 02-03-2012, 16:05
GCentola's Avatar
AKA: Garrick
no team (SparX)
Speaking of low traction, that seems to be the death of 1 Co-op point. If both alliances are on the C-Bridge, but it isnt balanced, you still get one CP each, but it looks like right after the match ends, the bridge tips to one side and the one on top pushes the other one off accidentally when it slides down.
GO SparX on 3!!!!!
Check us out at:
Unread 02-03-2012, 16:07
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
I'd be weary of doing this. It might get you flagged for unnecessary aggression. It's also not in the nature of GP...do you want your team to be known as "that team who flips over other bots"?
Unread 02-03-2012, 16:13
AdamHeard's Avatar
Lead Mentor
I don't think his statement was in regards to how to intentionally tip the opponent, but rather pointing out how many teams have repeated this same operation to tip their opponents today in the process of trying to legitimately cooperate.
Unread 02-03-2012, 16:17
FRC #0023 (PNTA)
Rookie Year: 1620
Oh, I see. Silly me
Unread 02-03-2012, 17:32
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
I expect this will be like mini bots last year. By week three there where 2 or 3 methods that made it look easy.
I was a little surprised how easy it is to flip a bot. Seeing it makes it kinda a DUH. Agreed that it does not seem to be intentional. But if you see the other robot backing away from you and you are more than half off it, you need to be on the gas following it.
Unread 02-03-2012, 18:51
mwmac's Avatar
mwmac mwmac is offline
JWBWIFWWWADD
AKA: Mike MacLean
FRC #2122 (Team Tators)
mwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond repute
Saw a few teams with 4wd that struggled getting the second pair of wheels on the bridge once it started to tip
Unread 02-03-2012, 22:55
Kimmeh's Avatar
Kimmeh Kimmeh is offline
Student at Kettering University
AKA: Kimberly
FRC #0068 (Truck Town Thunder)
Kimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond reputeKimmeh has a reputation beyond repute
Send a message via Yahoo to Kimmeh
At Kettering there seems to be a fairly consistent planned attempt for the cooperation bridge. (Whether is works is a different story however...)
And yes, the second robot pushing the first robot on the bridge works better than each team trying to balance individually. Warning: Less is more. Small baby steps will get you further than plowing straight through.
[2014 - Present] 68 Truck Town Thunder| Mentor |2014 - Great Lakes Bay Winner, Curie Quarterfinalists, District Chairman's Award, MCS Chairman's Award, Industrial Design Award, Entrepreneurship Award
[2014 - Present] 5046 Jacked Up Jackets| Mentor |
[2010 - 2013] 3421 Tachyon TECs| Mentor |2010 - Rookie Inspiration Award; 2013 - Coopertition Award , Kettering Quarterfinalists - 2nd Seed, Livonia Quarterfinalists - 2nd Seed Captain
[2009 - 2010] 2604 Metal and Soul| Student | 2010 - Gracious Professionalism Award, UL Industrial Safety Award
Unread 02-03-2012, 23:15
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
I was the driving mentor/instructor for 174 this year, and I can say we have practiced the art of balancing every chance we could. Mastering such a thing is always difficult for anyone as a slight movement alters everything. But the number one thing we discussed was allowing time to score on the bridge and being ready for a team that makes a last second mad dash. If we get on the bridge with 30 seconds, or even a whole minute left on the clock, as long as it will end up with +10, +20 or +40 to our score (or +2 qualifying points) it will be worth it.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 02-03-2012, 23:20
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Definitely discuss pre-match. I usually go out and find our alliance members 3 matches in advance to discuss these things.
My thoughts exactly. Our team was struggling but once I realized this, it was a good thing.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
