Go to Post I think that everyone should just take a step back and look at the whole picture, FIRST is a family, not an organization full of regions, we all try to help each other, not 'cause it benefits us, but because it's graciously proffesional. - Mike Schroeder [more]
  #31   Spotlight this post!
Unread 02-03-2012, 18:51
PSHRobotics PSHRobotics is offline
FRC #1182
PSHRobotics is an unknown quantity at this point
Re: Transmitting data to the cRIO from the Driver's station via TCP/UDP
So we tried doing this same thing with out dashboard and robot. Specifically sending three enum values from the dashboard to the robot. We got this working when we were running live on the robot through labview on a development computer. We would get one of the "The loop containing the RobotDrive code is running to slowly" error every once in a while but the code would function almost perfectly.
Once we deployed the code to the robot ("set as startup" after building), however, we started to get "Watchdog not fed" errors that would stop the code. Once we pulled the UDP receive stuff from the code on the robot, everything started working right. We decided to use the digitial inputs on the driverstation instead, but I would like to figure out what we did wrong in the old code. Does anyone have any ideas why this would have happened?
