Re: How to vibration isolate camera ?
Dave,
Much of the vibration that is transmitted is likely moving the frame for your turret so I am guessing that the camera is mounted somewhere on the turret frame. If you are using something that solidly attaches to the robot frame like a lazy susan bearing or some other low vibration mounting, getting the camera mounted as close to that point would eliminate much of the vibration in the camera. You would likely have more luck if you were to isolate the shooter from the turret as the camera does not contain enough mass to easily isolate it. |
I'll also throw my advice towards eliminating the source of the vibration rather than trying to isolate the camera from a vibrating frame. If nothing else, try with other wheels of the same model to see which introduce the least vibration. Another stiffener you may try is guy wires to anchor it to the corners of the robot.
To modify the frequency of the vibration transmitted to the camera, you may try some different density of rubber, polystyrene, urethane, etc. If you can extend the bolt, add a rubber bushing to hold the bolt away from the edges of the mounting hold, and add the right density of material on each side, you can certainly improve things, and of course adding some mass to the mounted camera will modify the period too. Keep in mind that the camera exposure is probably between 5 and 50ms, depending on the lighting -- faster on the field, slower in the dim shop/classroom. Greg McKaskle |
Thanks all good ideas. Clearly our shooter direct had excessive vibration. This morning it would hit a resonance point say at 3/4 full power and the whole assembly would become a blur due to vibration, then it would smooth out at faster speeds. We have since completely redone the drive train and improved the wheel hubs to try to solve this (will know tomorrow).
Made the first step to flex mount the camera but as someone said it is so light. May not be necessary we hope. Some guy was talking about using a "mass balance" system of counter weights to isolate the camera (I am guessing the counter weights vibrate out of phase to the frame vibration to net it out. Anyone know anything about this. |
