Go to Post I can't wait to get to St. Louis!! Oh wait.. I'm already here!! - Team 288 [more]
Unread 02-03-2012, 18:01
farmersvilleRob's Avatar
farmersvilleRob farmersvilleRob is offline
FRC #4084
farmersvilleRob is infamous around these parts
Aluminum Strengths?
Any idea on the strength of any of the 6061, 6063 or other high grade "airplane" aluminum when it gets down to .125 and . 06275 of an inch? And are there any special ways we could have this aluminum piece be coated with something to electrically isolate it?
Unread 02-03-2012, 18:25
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Aluminum Strengths?
For AA 6061 sheet, see page 3-264 of MMPDS-01. Be sure to verify the AMS specification to make sure you've got the right material for these tables.
AA 6063 is not a typical aircraft alloy—it's quite weak. (Actually, neither is AA 6061, but at least it's a fair bit stronger.)
AA 7075 (page 3-371) and AA 2024 (page 3-71) are more common high-strength aircraft alloys.
As for electrical isolation, maybe a paint or conformal coating? Epoxy-based, perhaps?
Unread 02-03-2012, 18:43
President, VEX Robotics, Inc.
When it comes to Aluminum you have to mind the post processing, too. 6061 is very weak, but 6061-T6 is quite strong. The T-6 designation is a quenching procedure in hot oil which increases both the yield and ultimate strength of aluminum. There are many other aluminum grades, like 5052-H34, which we use for all of our sheet metal.
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 02-03-2012, 19:02
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
For insulating it Plasti-Dip will work with proper application at the nominal 12v level. Depending on what you want to insulate the spray version may be the better choice.
Unread 02-03-2012, 19:09
FRC #4084
Thanks guys. How thick would you guess that both of those insulators are when applied? I would like for what I'm isolating to be less than .125" but I'll take what I can get. Also, I meant 6061-T6 lol my bad.
edit: Would like the insulator I'm applying to be <.125"
Unread 02-03-2012, 19:35
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
When you ask how strong or what the strength of something is, please provide more details in the application (i.e. bending, tension, compression, fatigue, fasteners, etc)
Some have mentioned typical alloys 5052-H34, 6061-T6, 7075-T6. In addition to these 5052-H32 and 2024-T3. This list contains the alloys that are (typically) used and kept in stock at the aircraft modification shop that i work at.
Also, is it extremely important to find a sheet of aluminum that is 0.06275"? The fractional size of 1/16th (0.0625") is usually sold as 0.063". Please inquire if you have any other questions. Sheet metal design can be very useful, IF you know how and where to use it.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 02-03-2012, 20:16
Mr V's Avatar
FRC #5588 (Reign)
Here is the Plasti Dip spec sheet. http://www.plastidip.com/docs/plastidip_uv.pdf How thick the coating is depends on how you apply it and how many coats you use. It claims a diectric strength of 1400v/mil but also recommends a minimum thickness of 12-15mil "for best results". So yes way less than 125mil
Unread 02-03-2012, 20:18
FRC #4084
I'm sorry that I can't be detailed on the application, but the impulse on lets say just this 1/16th of an inch thick aluminum shape is ~4.5 Kg m/s of compression. The only other force would be an optional fastener (servo screw more than likely) that doesn't support anything. Also, this wouldn't be flat bought, but rather manufactured so beginning size isn't that big of an issue.
Unread 02-03-2012, 20:20
FRC #4084
Thank you! I will definitely bring this up in our conference call.
Unread 02-03-2012, 23:26
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Not to take things TOO far off track, but I was under the impression that -T6 temper was an artificial aging process that would just involve holding the material at a somewhat elevated temperature for a few hours. Specifically, 375F for about 9 hours, according to one google hit. I suppose you could do this in an oil bath, but I don't think I'd call it a quenching process....
Unread 03-03-2012, 04:05
Kevin,
All of the -T tempers are "solution heat treated", then quenched. Sometimes water, sometimes oil. T6 is specifically at 900 degrees then artificially aged for 8ish hours after quench.
Paul
Unread 03-03-2012, 04:10
qzrrbz qzrrbz is offline
FRC #0469
qzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to behold
It's true! Paul is up 24x7 during comp season! :-)
Unread 07-03-2012, 09:30
Generator of Entropy
FRC #2973 (The Mad Rockers)
Be careful with 6XXX series aluminum in welded applications - the strength in the heat affected zone drops by as much as 75% (9 ksi instead of 36 ksi for 6061-T6 tensile yield).
Unread 07-03-2012, 10:06
Kevin,
Paul
Shows how much I remember from my materials classes of almost a decade ago. Use it or lose it, as they say. So the heat treat goes Solutionizing -> Quenching -> Artificial Aging. Which makes sense now that I think about it.
Unread 07-03-2012, 14:50
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Anodizing aluminum will make the surface of the metal non conductive. Painting, nylon dip, will also make the surface non conductive. Chem.-Film or alodine will coat the surface but will be electrically conductive.
Structural shapes like angles, tubes, extrusion, made from .125" 6061 material are plenty strong. Great for load bearing but a bit on the heavy side. We only use .125" thick alum for parts outside the bumper zone and we expect to be hit. We use .062" thick alum 6061 for most tubes. It is a good trade off for being lightweight and strong. Our shooter super structure for this years robot is made from .035 thick 1.25 dia round tube. We use a glued and rivet construction method and it is super strong and lightweight. We really did a good job.
We use 5052 H32 for all of our sheet metal parts. The chassis is made from .090" 5052. The brackets are mostly made from .062" 5052
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
