Go to Post A sign of character is the ability to move on and make the best of what you have, even if you feel you were completely wronged. - Cory [more]
Unread 03-03-2012, 04:01
pigpenguin's Avatar
pigpenguin pigpenguin is offline
Registered insane
AKA: Ethan Rooke
FRC #1160 (Titanium Robotics)
pigpenguin is an unknown quantity at this point
Cadding images
Basically it has come time to make a cad model of our logo. So I know you can import an image and sketch over it. But I have a vector file of the logo is there any easy way to pipe that into cad and just use it as a sketch? Thanks ahead of time,
Ethan Rooke
"Insanity isn't a plea its a way of life and here we are all one card short"
Unread 03-03-2012, 04:47
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Cadding images
Ethan Rooke
Which CAD Package? Solidworks? Inventor? Pro.E?
-RC
R.C.
MadTown Robotics Team 1323
Unread 05-03-2012, 20:07
pigpenguin's Avatar
Registered insane
AKA: Ethan Rooke
Re: Cadding images
inventor
Unread 05-03-2012, 20:58
KennyLives's Avatar
KennyLives KennyLives is offline
Grand Vizier of Pneumadynes
AKA: Kenneth Prouty
FRC #2122 (Team Tators)
KennyLives is an unknown quantity at this point
Re: Cadding images
inventor
What format of image? Also, I find Solidworks IS better at this.
No leaks. Ever.
Unread 05-03-2012, 22:33
pigpenguin's Avatar
Registered insane
AKA: Ethan Rooke
Re: Cadding images
I have it in a vector format (adobe illustrator) but can save it as any type. I would think inventor would have a way to import paths from a vector but I could be wrong.
Unread 06-03-2012, 16:25
crazyStone crazyStone is offline
Cad posessed
AKA: Derek Stone
no team (Charger Robotics)
Team Role: CAD
crazyStone has a spectacular aura aboutcrazyStone has a spectacular aura aboutcrazyStone has a spectacular aura about
Re: Cadding images
The easiest way to insert a logo into inventor is to save it as a bitmap (.bmp) yes i know it kills the quality out of adobe. then you go to "insert" tab once you open a sketch on the surface you want the logo, then click "decal" under the "modify" tab and place the image as a decal on that surface. Hope this helps, we did this an our logo turned out decently.
Unread 07-03-2012, 17:34
pigpenguin's Avatar
Registered insane
AKA: Ethan Rooke
Re: Cadding images
Yeah we have done that as well, we actually were asked to get it cadded so it could be machined. I worked out how to do it from the illustrator side of things; you can just export it to a dwg and then work with it in inventor. So we got that working but I still find it odd that inventor does not have the feature to work with paths in .svg files and such.
Unread 07-03-2012, 22:14
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
Re: Cadding images
Hey, Ethan.
Sorry it took me a while to get back to this thread, but I checked Illustrator, and it turns out CS5 can convert directly to Autodesk .dwg and .dxf files, both of which can be opened in Inventor and run on a CNC. (Goto File>Export and select .dxf or .dwg).
In other words, do the conversion in Illustrator instead of in Inventor
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 07-03-2012, 22:39
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: Cadding images
When we want machine our logo, we turn it directly into a dwg, and import it into our CAM package, BobCAD. Them we create gcode and machine. Just letting you know, you don't necesarily need to go through inventor.
As to how we get our logo as a dwg, I'm afraid I can't be of much help.
-Plutarch
Unread 08-03-2012, 11:31
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Re: Cadding images
All,
This is an example of identifying the function of the data output. In this case it appears that it is machining a logo, so a DWG or DXF will meet the needs of the CNC machine shop.
Inventor could be used, but as highlighted by msimon785, the source software of the image can output as DWG or DXF.
Good discussion.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
