Go to Post This is an open forum and it is a privilege to post here, if you don't agree with the rules then just don't post here. - dez250 [more]
Unread 03-03-2012, 14:21
mbone206 mbone206 is offline
FRC #0223
mbone206 is an unknown quantity at this point
how make room on dash - bigger for new indicators
Hi All
trying to make room on dash for new indicators:
* resize dash, I can resize in debug mode for larger screep lap top as driver sation, but when run as .exe, seems to default back to original size. Played with control panal display, but only get what resilution allows, does not help much... is it feasible to resize dash?
* Alan said his team made control tab, put debug indicators in that tab, created another tab, put desired indicators there.. thanx Alan.. but seached how to do this in help, still can not find the TAB control.. also stepped thru every pallet.. Can someone tel me how? Help indicated under 'generic', but right click on screen still can not find generic ontrols option
mark
Unread 03-03-2012, 14:30
Re: how make room on dash - bigger for new indicators
Towards the left and bottom of the Dashboard diagram i think you'll find code that checks if the login name is Driver and sets the window position and size. Update the code or delete it.
Greg Mckaskle
Unread 03-03-2012, 14:50
FRC #0223
TAB contol? Re: how make room on dash - bigger for new indicators
Thanx Greg, awesome
* can you still help where to find tab control, would like to try and put defaulut indicators in it as someone recommended
Unread 03-03-2012, 15:26
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Re: TAB contol? Re: how make room on dash - bigger for new indicators
Open up Dashboard Main.vi and right click. Go to Modern>>Containers>>Tab Control. You can right click these tabs to add or delete "Pages". To write in them, create a text box and move it into the desired tab. You can also drop indicators onto tabs.
Unread 03-03-2012, 17:32
FRC #0223
Thank You Dominick...........
