Go to Post FIRST is like riding a bike. At first it may seem hard and confusing, but after a few tries you get the hang of it and its smooth sailing from then on out. - Tom Bottiglieri [more]
Unread 03-03-2012, 17:47
Whateveryousay's Avatar
Whateveryousay Whateveryousay is offline
Team 1683 Techno Titans
AKA: Tony Chen
FRC #1683 (Techno Titans)
Whateveryousay is an unknown quantity at this point
Where to find aluminum sprockets?
We are in a bit weight trouble, so we want to swap some of our mcmaster sprockets out for aluminum ones. Does anyone know any website who sells aluminum sprokets for half inch shaft that has around 20 teeth? We cannot find any, but we remember some place back in 2008 where we got it. We need hubs on these sprockets.
Thanks a lot for helping us.
2011 Peachtree Regional Innovation in Control Award
2011 Peachtree Regional Semifinalist
2010 Peachtree Regional Champion
2010 Peachtree Regional Creativity Award
2008 Peachtree Regional Finalist
2007 Bayou Regional Champion
2006 Peachtree Regional Finalist
2005 Peachtree Regional Quarterfinalist
Unread 03-03-2012, 17:55
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Where to find aluminum sprockets?
Andymark sells aluminum sprockets
Unread 03-03-2012, 17:56
AKA: Tony Chen
We looked at those, but we would like some aluminum sprockets with hubs. The ones on Andymark do not have hubs if there are more than 12 teeth. We would like around 20
Unread 03-03-2012, 18:05
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Hubs can be made with the right equipment.
Some more details about exactly what type of sprocket you need could help. Not all vendors carry every type of sprocket.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 03-03-2012, 18:08
AKA: Tony Chen
Our team does not have CNC or milling machines, so it will be hard for us to machine a hub.
We need ANSI 35 chain sprockets, around 20 teeth, Half inch shaft, perferrably 1/8 key way or set screw is acceptable too
Unread 03-03-2012, 18:09
AKA: Tony Chen
We already looked on Robotmarketplace, Andymark, McMaster and Grainger, are there more websites selling these kinds of parts?
Unread 03-03-2012, 18:28
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
AndyMark sells hubs too.
But what about this plus this?
Last edited by Tristan Lall : 03-03-2012 at 18:31. Reason: Giving a more useful recommendation.
Unread 03-03-2012, 18:33
DonRotolo's Avatar
Back to humble
FRC #0832
You do not need a milling machine, or CNC equipment, to make a hub. All you *really* need is a drill press. Having a lathe might make things easier, but it is not absolutely necessary.
Unread 03-03-2012, 20:57
Sb28000's Avatar
Sb28000 Sb28000 is offline
FRC #2656 (Quasics)
Sb28000 is on a distinguished road
I've got to say that I don't have any specific recommendations for vendors as I've never searched for that particular part - But one thing to consider is how much weight you can actually save by doing this, and "weigh" that in comparison to the amount of time/effort/money it may take to find, and then swap out, the aluminum sprockets. Unless you have a lot of them of your robot, it may not provide a significant reduction in weight (If you only have, say, 8 sprockets on your drivetrain). You may want to look into some other places to cut weight, such as switching to lighter bolts (or using rivets), or removing/lightening any nonessential parts, or using thinner materials. There are plenty of threads about other ideas for making your robot lighter (Like using the new(er) plastic pneumatics tanks, as opposed to the metal Clippard tanks -if you're even using pneumatics. That's just one idea though). However, if you do decide its worth pursuing to switch the sprockets, best of luck in finding hubs/sprockets that will work for you!
Pittsburgh Regional Finalists 2010
Hoping to come back strong in 2012!
Unread 03-03-2012, 22:31
AKA: Tony Chen
Thanks, we only needs to swap 6 sprockets out, but we are currently using the McMaster stainless stell black finish sprockets, they are HEAVY, so yeah, we can save about 2 pounds by swaping all of them out, we are only 3 pounds overweight at this points. We did place an order on those plastic tanks and new compressor to save weight, but we would like to be a bit safer, you know just in case
Unread 03-03-2012, 22:38
Billfred's Avatar
Billfred Billfred is offline
I take it your robot uses live axles on drive? Dead axles would allow you to mount the sprocket to the wheel directly, saving more weight and allowing many of the existing aluminum sprocket options...but I'm assuming you've made your choice and are running with it in this regard.
Going with the AndyMark sprockets and hubs together is probably the easiest solution, though you may also be able to lighten your existing ones with a little swiss cheese in a desperation move. (Do that carefully, of course.)
You could also run your compressor off-board, which could drop a couple of pounds easily if you can run your matches with your tanks pre-charged.
Unread 03-03-2012, 22:41
Sb28000's Avatar
FRC #2656 (Quasics)
Okay, gotcha. Then if you're that close on weight and already making some other amends, trying to switch those sprockets out does seem reasonable (and I'm impressed/surprised it adds up to 2 pounds, that's pretty significant!). The new compressor and tanks really do help by a lot though (likely more than one pound, quite possibly even off-setting the three that you are over). However, making yourself a pound or so underweight couldn't hurt, right? Ya never know what will come up during competition.
