Go to Post For me Gracious Professionalism is about helping other teams make their ideas work. We do everything we can to help other teams program, or lend them parts from our pit. On the field we play to win. - Alpha Beta [more]
Unread 04-03-2012, 11:20
fovea1959's Avatar
fovea1959 fovea1959 is online now
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
recommendation for an easy to adapt ARA motor?
"more power Scotty": our bridge arm does not have enough downforce. Part of it is gearing, part of it may be we need a more powerful motor than the PG71 we are using.
We've pretty much gone through all the slow speed motors available to us (used both Window motors, the PG71 does not seem to be cutting it). A highly stepped down banebots or Andy Mark planetary may work also, but I'm thinking about doing a chain drive from an ARA available motor.
Does anyone have a recommendation for a particular automotive motor that would be easy to adapt to a #25 or #35 chain sprocket or Gates sprocket?
("the driver's side van door motor from a 1959 Cadillac has a 1/2" output shaft..."). We have 3 weeks to next competition, arm assembly is out of the bag as part of our 30lb withholding....
We don't have decent machining facilities... we *do* have a pile of the old shaft adapters from past year window motors...
Unread 04-03-2012, 11:30
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: recommendation for an easy to adapt ARA motor?
http://www.andymark.com/Van-Door-mot...-p/fc12-72.htm The page lists different car models you can source from.
Might not be the easiest to attach to, but it's a start.
Unread 04-03-2012, 23:17
fovea1959's Avatar
AKA: Doug Wegscheid
tomorrow is supposed to be a robot holiday after the competition, but I'm sure we have one of those around from a past KoP, plus we haven't burnt all our FirstChoice points. thanks for the tip...
