Go to Post I wonder if Dave thinks the Chief Delphi kids are pimp... - Mike Ciance [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 01-03-2012, 14:43
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
Re: polycord problems
We insert the two ends into a short piece of heatshrink of the same diameter, and then use a plastic welding tool to melt the two ends together inside the heatshrink. The plastic melts before the heatshrink burns.
Unread 02-03-2012, 09:58
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Originally Posted by JCharlton View Post
Please do not use a flame to weld polycord, the fumes are toxic!
Besides, using a hot air gun works better. Put the cord behind a hole in a piece of aluminum to shield it so only the ends are exposed. When it gets good and soft push it together making a round ball at the joint. Hold it in the 'L' of a piece of aluminum angle to keep it straight as it cools, then cut and sand the excess off. Never had a failure.
Good luck, and say hi to Joe and Tom for me!
After years of using a soldering iron with a flat tip, last night tried it with a heat gun. Worked great.
Unread 04-03-2012, 15:55
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
1640 uses the magic tool from McMaster. Perfect tool for the job. Makes nice clean joints. Key thing is to read and follow the instructions. Many are loath to do that, but only through the Zen like state of enlightenment from following the directions will you have success.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 04-03-2012, 16:45
atlas atlas is offline
Atlas
FRC #1817 (Llano Estacado RoboRaiders)
atlas is an unknown quantity at this point
Use a heat gun, it works much better than a soldering iron. Also try using 1/4", its easier to fuse in my opinion. Be sure to get fully melt the center of the polycord as well. And lastly, be sure not to "over-melt" the ends, if it gets to messy they will not fuse together correctly.
Hope this helps.
"Trust, but verify."
1768 >> 1817
Student >> Mentor
Unread 20-03-2012, 08:21
Countryman's Avatar
Countryman Countryman is offline
AKA: Nolan Gordon
FRC #0716 (Who'SCTEKS)
Team Role: Human Player
Countryman is an unknown quantity at this point
we use a sauntering tool and use the edges, melt the ends and then hold them together until the cool down and are tight.
