Go to Post ...he's acting like a programmer whose code is compiling...:yikes: - EricH [more]
Unread 04-03-2012, 17:07
Re: Cim-Sim gearbox for shooter questions
Originally Posted by RoboCat2005 View Post
Thanks we worked hard on the system for getting over, we based it on the NASA Rocker Bogie system.
To answer the questions:
-2 Fisher Price motors
-Started with 6" now has a 4" in it
-With the 6" it had about an 1.5" almost 2" of compression, although it happens early and the exit is a little less then at the beginning.
-it bogs the motors down quite a bit as the ball drops in
-Each motor is hooked up to a jag each and the motors run at full speed when the ball is introduced.
what Fisher Price motors are you using? there are 5 different legal FP motors this year
what is the gear ratio from motor rpm to wheel rpm ?
how fast is the wheel spinning ? -or- how many amps is the motor pulling ?
Unread 04-03-2012, 17:15
RoboCat2005 RoboCat2005 is offline
AKA: Catlin Level
FRC #3659 (Mighty Patriots)
RoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to all
-We are using the 2 new FP that were in this years kit.
-Gear ratio off of the output of the gear box is a little over 1:1, a 24 tooth sprocket on the gearbox to a 22 tooth on the wheel.
-honestly could not tell you how fast the wheel is spinning or the amperage.
FRC Team 3659 Mighty Patriots- Mentor/Drive Team Coach(2015-)
FRC Team 3345 Metal Jackets- Build Team Mentor (2012-2014)
FRC Team 2969 Hurricane Robotics - Lead Mentor/ Drive Team Coach (2011/2012 seasons)
FRC Team 399 Eagle Robotics - Student Alumni (2002-2005)
2011 Alamo Regional - Xerox Creativity Award(2969), Referee
2012 Alamo Regional - Quarter Finalist
2012 Lonestar Regional -Semi-Finalist
2012 Lonestar Regional -Xerox Creativity Award Winners
Unread 04-03-2012, 17:21
nitneylion452's Avatar
AKA: Joe Lee
What is the reduction in the gearbox?
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 04-03-2012, 17:31
I'll assume that means FP00968-9013
Well, if everything was spinning freely with no friction,
16700	motor free rpm
5	gear reduction
0.917	gear reduction
3642	wheel free rpm
60.7	wheel free rev/sec
4.0	wheel diameter, inches
1.05	wheel circumference, feet
63.6	wheel tangential free speed, ft/sec
That ought to be plenty fast.
How tight is that chain ?
That's a critical piece of info to diagnose the problem from afar.
