Go to Post Just a word of advise dont come running up to someone and say OMG OMG its just remember to introduce yourself first. - Mike Schroeder [more]
Unread 04-03-2012, 17:23
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Cim-Sim gearbox for shooter questions
Originally Posted by RoboCat2005 View Post
Thanks we worked hard on the system for getting over, we based it on the NASA Rocker Bogie system.
To answer the questions:
-2 Fisher Price motors
-Started with 6" now has a 4" in it
-With the 6" it had about an 1.5" almost 2" of compression, although it happens early and the exit is a little less then at the beginning.
-it bogs the motors down quite a bit as the ball drops in
-Each motor is hooked up to a jag each and the motors run at full speed when the ball is introduced.
If you're only running about 0.5 to 1" of compression now, you really shouldn't be bogging those motors down, even if those are the weaker FPs. You really shouldn't be having problems if you have 0673 FPs. Do you have any guess how much current the motors are pulling when it's running without any balls? It should be something less than 10 amps. Anything more means you have some serious mechanical binding somewhere.
Frankly, your system looks like it should manage better than a foot or two. I'm leaning towards there being some significant mechanical resistance somewhere in your system. Your sprocket-chain connect there is a possibility. I'd also look at your bearing system for the axle of those shooter wheels and make sure you don't have any resistance anywhere. Some of my kids had a shaft collar rubbing against an aluminum retaining plate. It warmed up the shaft nicely and also slowed done the shooter a good bit.
I guess the other thing I would do is make sure both motors are actually running and pushing the shooter in the right direction. You can check that by unplugging one of the motors at a time and making sure the wheel still turns and in the correct direction.
EDIT: Now that I see you're runnig the new 170W FPs, you might as well swap those out for a pair of the BaneBots RS-550 motors. Those are 250ish watts but otherwise physically identical to the FP motors. That'll atleast give you a little more speed and torque.
Unread 04-03-2012, 17:33
RoboCat2005 RoboCat2005 is offline
AKA: Catlin Level
FRC #3659 (Mighty Patriots)
RoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to all
As of right now the wheel and the sprocket set up spin extremely free and no binding in there, the motors are both spinning and in the right direction, weve checked that a lot. But pretty much as the ball drops in from the top the motors bog down and the ball just kind of flops out with no energy at all.
FRC Team 3659 Mighty Patriots- Mentor/Drive Team Coach(2015-)
FRC Team 3345 Metal Jackets- Build Team Mentor (2012-2014)
FRC Team 2969 Hurricane Robotics - Lead Mentor/ Drive Team Coach (2011/2012 seasons)
FRC Team 399 Eagle Robotics - Student Alumni (2002-2005)
2011 Alamo Regional - Xerox Creativity Award(2969), Referee
2012 Alamo Regional - Quarter Finalist
2012 Lonestar Regional -Semi-Finalist
2012 Lonestar Regional -Xerox Creativity Award Winners
Unread 04-03-2012, 18:08
This is turning into a stumper. The only advantage the rest of us have over you is that our 6" and 8" wheels have more rotational inertia than your 4" wheel. So your 4" wheel doesn't store as much energy and more of the energy for the shot has to come from your motors.
This might explain everything, though. Your wheel would be losing most of its energy at the beginning when it's just pulling the ball and starting to compress. Then it's running slower through the high compression and you don't have enough compression afterward to make up for it. If you don't have good grip on your wheels, that'd likely make things even worse, wasting what little stored energy you have in friction while the wheels are slipping.
I think you'd probably be best off by increasing the grip on your wheels and trying to increase their rotational inertia. You can do that by increasing the mass or the diameter of the shooter wheel. Or both. Or by attaching a separate flywheel to your shooter axle somewhere it won't interfere with firing the ball.
Unread 04-03-2012, 18:12
Also, also, were you getting the same symptoms with the 6" wheels? Why'd you switch away from those? We're running:
- 2x -0673 FPs (~600W)
- CIM-SIM direct drive
- 2x 6" AM performance wheels
- ~1.5" compression
We're getting pretty good distance out of this setup, shooting from the key at about 70% drive on the motors.
Unread 04-03-2012, 18:25
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
- ~1.5" compression
  • 2 9015's
  • 2 CIM-Sims through 2 Gates belts with no reduction
  • 4X 8" past KOP wheels
  • ~1.5" compression
  • 60° launch angle
It's working great for us. I think we need 50-60% to shoot from the key. We keep our gearboxes nice and greased. Grease would fly if you added anymore.
AKA: Catlin Level
- ~1.5" compression
The 6" actually worked a little bit better then the 4", we switched to the 4" on Saturday morning to try it and it we actually took a step back. We had a mentor from the GatorZillas come over and he said we had way to much compression early, as in when the ball first hits, and not enough on exit; this was with the 6" in. So we tried switching to a smaller wheel to try to counter that. We cant just turn the hood around, otherwise we would have done that.
The 6" wheel is the AM white plastic hard wheel, and the 4" is the plastic one that was on the FIRST Choice list.
Unread 04-03-2012, 20:04
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud of
Our team is using Cim-Sims with the 9015 motors, one on each gear box. But we have a shooter with two pairs of wheels with one gear box for each pair of wheels. The hood drag is too great in your design. The wheels may have sufficient linear velocity, but the the hood is keeping the ball from getting up to speed. In short, there probably is a lit of slippage of the wheels against the ball.
With our design, we have four 5 3/4 in diameter by 3/4 in. aluminum wheels in our shooter. Two disks to a axle. Once we spin up, the balls move through with very little decrease in speed of the wheels. We shoot 32 ft. with an arc 16 ft. high.
I'd look at ways to cut down on the drag in the hood.
Dr. Bob
Chairman's Award is not about building the robot. Every team builds a robot.
Unread 04-03-2012, 20:14
Your problem with the 6" wheels may have been too much compression too quickly. Your problem with the 4" wheels is definitely the lack of compression through most of your shooter. I understand that you can't flip the hood around or anything at this point. I think you still have options for increasing your exit compression now that you have 4" wheels. You need to make up a liner for the exit side of your hood. This can probably be a piece of lexan that fits inside the hood, and a few spacers made of wood or something that push the lexan away from the hood and closer to your wheel, increasing your compression. You might also benefit from friction tape on your wheels to make them grippier, and I still recommend a flywheel or heavier wheels so you can store up energy and your wheels can maintain a higher speed as the ball goes through.
Unread 04-03-2012, 23:38
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Thumbs up Re: Cim-Sim gearbox for shooter questions
I don't think you will be able to swap your Andy-Mark 9015 motors (am-0912) for the Bane-Bot motors because the output shaft dimensions are different. I have both sitting in front of me and can see that the output shafts are different. The Bane Bot output shaft is significantly shorter in length. Note that the Bane-Bot 550's I have in hand have been recently ordered (new for 2012). YMMV (your mileage may vary).
I am also seconding Kevin's suggestion above for the additional flywheel on your bottom wheels. We added this on Saturday to produce significantly more ball spin. Cavaet - not fully tested.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 04-03-2012, 23:56
How long to the shafts really need to be? Our -0673 shafts were way too long to easily get 100% engagement anyways. I think you could get the Banebots motors to work fairly easily.
Unread 05-03-2012, 00:17
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
We are using 2 BB RS550s, Cim-Sim, 26:17 chain increase driving 2 8 in. wheels. We can easily shoot from the top of the key, and even sink the bottom basket while on the bridge.
The 550s easily have enough shaft to engage the pinions. The key is to mount them with a set screw or Loctite 609 retaining compound (or similar product), or both.
Unread 05-03-2012, 02:46
AKA: Catlin Level
Is that 26:17 is that the teeth on each sprocket? and by what you have stated guessing it speeds is up to a decent speed? We had a 32 tooth to a 12 tooth speed increase and the best we could get was during autonomous, place the robot back wheels touching the free throw and could hit the front corner of the fender.
Unread 14-03-2012, 11:27
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
We have been using a Banebot Cim-U-lator with the dual 550 motor setup.
We have adjacent dual 8" AM gray urethane wheels on a 5/8" shaft with a 1:1 ratio 30 tooth pulley pair drive. The balls are pinched against a mostly flat 1/4" plywood sheet with its surface covered by high friction shelf liner.
The plywood is slightly bent at entry end to give a funnel shape. We have been able to shoot initially 40+ feet before we started having gearbox and/or motor troubles.
We did install spacers for maintaining airflow between the 550 motors and their gearboxes, using large 3/8" steel washers cut into a 4-lobe spider to match the vent & mount holes there.
We were initially burning up the 550 motors from a having a bad wire terminal connection arcing issue.
After that was fixed, we are still destroying the 550 bearing at the pinion gear end of the 550 shaft (two already). We broke in our gearboxes gradually before loading them, even changing grease after 1 hour.. They were running cool during the break in stage with everything spinning at full speed. Any ideas why motor bearing would self destruct so quickly -- 30 min to 90min of use and less than 100 shots?
We are converting today to the single 775 motor setup of the Cim-U-lator and testing for how much distance/RPM we lose from the fact that 775 is an 18V motor running at 12V. We can regear for more RPM if necessary, but we hope this larger motor can handle whatever the shaft loading issue is that is killing the 550 motor's front bearings. Any ideas why the 550 bearing nearest gearbox would be getting thoroughly chewed up so fast?
Which allowed AM motor(s) used this year with CIM-sim gearboxes are giving good distance for shooters?, and will any AM motors match up properly with the dual motor CIM-U-lator gearbox, as far as motor mounting and shaft diameter (in order to use same pinion gears as fit the 550 shaft)?
-Dick Ledford
Unread 14-03-2012, 11:57
Dan_Karol Dan_Karol is offline
Mentor and Coach
AKA: Daniel Karol
FRC #0131 (CHAOS)
Dan_Karol has a spectacular aura aboutDan_Karol has a spectacular aura about
Send a message via AIM to Dan_Karol
Ok, so having had similar problems I think I can shed some light for you.
There are a few factors that go into the shooter:
  1. Shooter wheel surface speed
  2. Shooter intake compression
  3. Shooter exit compression
  4. shooter contact distance
  5. Shooter Inertia
It sounds to me like with both the 6" and 4" wheels your surface speed should be about on target so I'm going to jump over this section.
From your description you say the intake to the shooter wheel has more compression then the exit. this causes almost all of the energy to go into compressing the ball very quickly in order to "suck" the ball down into your shooter. This expends a HUGE amount of energy on relatively non-productive areas. Our shooter has less then 0.5" of compression when the ball enters it and has about 1.5"-2" (depending on tilt angle and other factors). This setup has worked a lot better for us then constant compression at any distance (and we have tested it). I would suggest moving your shooter shaft forwards so the intake is looser and the exit is tighter. This is probably the simplest solution to your problem.
Because your shooter is almost 100deg you should have no issues with the contact time with the ball. If anything there may be to much here but I seriously doubt it.
After adjusting the shaft in the hood if your wheel still bogs down then this is probably the place to look. By increasing your inertia the shooter wheels wont take as much of a hit (and my team takes almost no hit) when a ball passes though the shooter helping whit your reliability, consistency, and range.
Hope this helps,
Dan
Unread 14-03-2012, 12:34
Originally Posted by Dan_Karol View Post
May I ask, to whom are you responding? There's no context in your post, and you linked it to Dick Ledford's post to which it appears to be unrelated.
