Re: Video of first ever triple balance
You can watch it retract at the end. 245 is in the way for the deployment.
If you look VERY close you can watch it work. The bridge lifts, THEN the robots push forward a little, and then it retracts back up. Suggesting they used their deployment device to level themselves with the bridge, bumped the robots forward just far enough, and then retracted their cylinder. Last edited by Zach O : 04-03-2012 at 22:46. |
Using sensors, my guess is it's hard to tell "how well" the bridge is balanced. Unless you can figure out the force being exerted on the cylinder, I suppose. A gyro would return you that you're level the moment you went up, regardless if the bridge would balanced if they brought the cylinder up. However, if you can judge the moment when the bridge truly levels out and the cylinder does less work than before, you could automatically decide when to bring up the cylinder.
