Go to Post You hang for show; kick for dough. - Travis Hoffman [more]
Unread 04-03-2012, 22:48
WarehouseCrew WarehouseCrew is offline
FRC #3299 (Warehouse Crew)
Team Role: Parent
WarehouseCrew is an unknown quantity at this point
Pushing down the bridge
It appears that the window motor (with arm attached) that works on our (and many other teams) practice bridge may not have enough torque to push down a competition bridge.
Would anyone with actual experience with a competition bridge comment on what motor and gearing appear to have the power necessary to push the bridge down?
Unread 04-03-2012, 22:49
Andrew Lawrence
Posts: n/a
Re: Pushing down the bridge
We used a Van Door motor for our bridge tipper. It works well on comeptition bridge. Gear it down a bit, though, just for the extra torque.
Unread 04-03-2012, 22:50
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
FisherPrice through the kiddy car gearbox works.
Unread 04-03-2012, 22:59
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
same
we have more than enough power
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 04-03-2012, 23:02
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
We used the van door motor and 4:1 gearing - so we are probably OK?
TIA
Unread 04-03-2012, 23:03
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
TIA
use a force plate and see if you can get about 16lbs of force. That seems to be about what it takes
Unread 04-03-2012, 23:05
Andrew Lawrence
Posts: n/a
TIA
It works for us, but please note we have a.....unique new bridge actuator that allows us to lower the bridge differently than others.
Most likely it will still work.
Unread 04-03-2012, 23:07
pfreivald's Avatar
AKA: Patrick Freivald
We weighed our bridge down more than was necessary and used the FP motor and gearbox -- not only would it tip the bridge, the bridge barely slowed it down.
Mind you, we haven't yet used it on an actual competition bridge (and that, as usual, makes me nervous), but it seems to have well more than enough torque to handle the job. (Of course, the length of your moment arm matters, too!)
Might I suggest that you do the math?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 04-03-2012, 23:10
Andrew Lawrence
Posts: n/a
And save the world?
Unread 04-03-2012, 23:11
Originally Posted by dellagd View Post
same
The funny thing is we wheelied onto the bridge...
Unread 04-03-2012, 23:13
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Here's my math,
We're planning on using the KOP, Andy Mark PG71 Gearmotor with almost 3: 1 sprocket ratio ( 22 tooth on PG71 attached via chain to 60 tooth gear). 60 tooth has arm mechanism. According to specs PG-71 stall torque is nearly 16.6 ft-lbs (Andy-Mark website) . Someone calculated that 20 foot -lbs was required to tip the bridge (CD website) based on the 2 batteries and distance demonstrated in one of the FIRST kick-off videos.
So, at 60% stall torque (10 ft-lbs) * (60/22) * favorite efficiency ratio (0.8) = 21.7 ft-lbs > 20 ft-lbs should work.
Distance from center of shaft for bridge arm is 6 inches (1/2 foot) on the 60 tooth sprocket , so theorectically placing > 40 ft-lbs on bridge at 60% full torque.
We didn't build a bridge (small team) but the bridge arm easily picks up the front end of our robot. Hope this helps.
BTW, PG71(am-0914) is powered by RS775 motor and has internal 71:1 gear set. KOP rules allow 2 units for 2012. Andy Mark also sells a 10 mm key hub that couples directly to the 10 mm output shaft (am-0985). You will need to also get a 4 mm key for the hub (am-1249).
So, for our assembly the Bill of Materials , from memory is the following:
1) PG71, 2) 10mm key hub, 3) 4 mm key, 4) 2 - 375 key hubs (am-0134), 5) 1 sprocket, (22 tooth - am0118), 6) 1 sprocket, (60 tooth - am0057). Need also 7) 3/8 shaft for the 2 - 375 key hubs (recommend 1 foot to start)- Andy Mark does not sell - McMaster-Carr and 8) 3/32 key stock for your 375 key hubs (am-1059, 2 pcs)
I have a second PG71 Gear motor ready to add if necessary (contingency plan).
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 04-03-2012, 23:16
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
The video said 28" to 30", so assuming 29" is the tipping point, 26" is the effective tipping point (CoG of battery isn't at the end). Keeping in mind that the bridge rotates on the edges of the bump and not the exact center, subtract another two more inches to get 24". Two batteries are 27 lb. That gives 27 lbf * 24" * (1'/12") = 54 lbf-ft = 648 lbf-in.
However, because of the double hinge, it's not a perfect lever, so aim for a bit more than that.
(88"/2) - 2" = 42"; 648 lbf-in / 42 in = 15.4 lbf, so approx. 16 lbf to tip.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 04-03-2012, 23:17
pfreivald's Avatar
And save the world?
No, no. And tip the bridge!
Team 1551
I write books, too!
Unread 04-03-2012, 23:19
Greg Shaw's Avatar
Greg Shaw Greg Shaw is offline
FRC #3601
Greg Shaw is a jewel in the roughGreg Shaw is a jewel in the roughGreg Shaw is a jewel in the rough
We were fortunate enough to travel to another teams location to practice on a competition replica bridge before the kettering event. Our original bridge arm was not strong enough. We eventually lowered the bridge by combining an andy mark PG67 gear and motor combo with a andymark tough box gearbox. the actual bridges are much harder to lower than the plywood version.
Greg Shaw
Lead Mentor
Proud Founding Member FRC Team 3601
Unread 04-03-2012, 23:28
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
AM PG-71 with 12 tooth #35 sprocket on the output, connecting to a 60 tooth sprocket bolted to a ~26" long arm (pivot to tip, wedge shaped). Works well.
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
