Go to Post This is not an engineering design challenge, this is a project management and common sense challenge with engineering elements. Don't go out of your way to screw yourself. - PayneTrain [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 05-03-2012, 06:51
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Hex Shaft Collar
Aluminum Clamp On Shaft Collar, 1/2" Hex Bore
Unread 05-03-2012, 09:25
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
We broached 3/8" shaft collars for 3/8th hex shaft ad it worked great!
Unread 08-03-2012, 17:50
Dripto Dripto is offline
AKA: Dripto Debroy
FRC #0694 (StuyPulse)
Team Role: Student
Dripto is an unknown quantity at this point
If you don't have enough collars of the right size (We never thought to check for ALUMINIUM collars, steel would have been overkill for our application) you can also take some aluminium rod stock, drill+broach the hex into it, and then file a flat to drill and tap! Worked great for us and get us the lightweight piece we needed.
Unread 08-03-2012, 20:26
Sh1ine Sh1ine is offline
FRC #2791
Sh1ine is on a distinguished road
We use shaft collars from McMaster. They are definitely overkill but work great.
Unread 08-03-2012, 21:12
Billfred's Avatar
Billfred Billfred is offline
If you have a lathe and know where you want to put things, an E-clip is also an option in some cases. (This is the route we chose on our ball rollers.)
