Go to Post Justin Bieber says "US FIRST" rather than just "FIRST". The irony. - Ankit S. [more]
Unread 25-12-2001, 15:29
PhillyRobotics PhillyRobotics is offline
#0920 (Lancers)
PhillyRobotics is an unknown quantity at this point
Send a message via AIM to PhillyRobotics
Exclamation Need help In Autodsek Inventor
Has anybody had the problem where Inventor quits when you are trying to save on WinME due to a problem in the kernal??
If so, any help would be very helpful
thanx Shrey
Unread 25-12-2001, 23:19
mnkysp6353's Avatar
mnkysp6353 mnkysp6353 is offline
no team (Bagel Bytes)
mnkysp6353 is an unknown quantity at this point
Send a message via AIM to mnkysp6353
aim me offline i may be able to help
my s/n is mnkysp6353@aol.com
Unread 25-12-2001, 23:20
mnkysp6353's Avatar
sorry mnkysp63530
Unread 26-12-2001, 22:10
Mike Carron Mike Carron is offline
#0343 (Metal In Motion)
Mike Carron is an unknown quantity at this point
Lightbulb Inventor on Windows Me
Shrey,
I'm not sure if you have solved your problem with Inventor or not, but here is my two cents worth.
I had Windows Me on my Compaq Presario and it also wouldn't run Inventor R3 or R4. The software would load fine, and all the functionality appeared to be intact until you attempted to do the "save" or "save as" command. I talked with Autodesk and they basically told me that Inventor wouldn't/couldn't be supported on Windows Me. I thought this seemed strange since the software was almost fully functional on Me. My solution, I upgraded my operating system to the new Windows XP platform and everything is working just fine now. Of course this cost 100 beans so it's not a cheap solution, but it was the only one I was able to come up with. I hope this helps.
Keep 'botting.
Mike Carron
Team 343 Metal In Motion
Project Manager
Tempest Fugit
Unread 26-12-2001, 22:30
David Kelly's Avatar
David Kelly David Kelly is offline
A Legacy of Impact
FRC #0234 (Cyber Blue)
David Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond repute
Send a message via AIM to David Kelly Send a message via Yahoo to David Kelly
Re: Inventor on Windows Me
Originally posted by Mike Carron
Shrey,
Keep 'botting.
Mike Carron
Project Manager
i have the opposite problem. Inventor 4 worked fine on ME but when i changed to XP, i couldn't even get the installer screen. version 3 works fine on XP but 4 doesn't. i havne't tried to load 5 yet but i'll prolly try it soon
2010 Indiana Robotics Invitational Planning Committee
2010 Boilermaker Regional
Chairman's Award, Regional Finalist
2010 Kansas City Regional
Entrepreneurship Award
2010 Championships
Autodesk Inventor Award Winner
Unread 26-12-2001, 22:49
FRC Key Volunteer Trainer
AKA: CrazyNate
Re: Re: Inventor on Windows Me
Try using the Compatibility settings on XP to make Inventor(or the setup program) think it is running under a different OS(95/98/etc). This seems to work in every XP compatibility case that I've run across so far...
Nate Smith
nsmith@smythsoft.com
Unread 26-12-2001, 23:27
A Legacy of Impact
Re: Re: Re: Inventor on Windows Me
i already tried that. and it was a no-go. also, it says that i have a copy already installed and it doesn't like the re-take the registration codes. that was after i re-formatted too. i'm still playin around with it.
2010 Championships
Unread 27-12-2001, 00:18
AKA: CrazyNate
Re: Re: Re: Re: Inventor on Windows Me
This is something with the product authorization through Autodesk. You're going to have to get ahold of them to get that reg code cleared(tell them it's a reinstall, and it should be ok, but I dunno)...
Nate Smith
Unread 27-12-2001, 07:57
Inventor on XP
David,
Have you tried doing an "uninstall" from the original Autodesk R3 CD versus just using the desktop add/remove programs function? I did an uninstall via CD first on mine. This will get rid of all the cdilla security codes that are embedded all over your computer. You should then be able to restart your computer and then load Inventor R4 with the new registration codes. Also, I believe Nate mentioned using the compatibility mode. I did have to set mine up by opening the program and setting the compatibility mode to Windows 2000. You do this by right clicking on the desktop icon and selecting right folder "compatibiltiy". There is a drop-down list that allows you to select the different operating system types. This is one of the BIGGEST features of Windows XP!!! I haven't found a piece of software yet that won't work doing this. Granted I haven't tried a lot of them, but all of my software that wouldn't work on Windows Me now works on XP. Just thought I would throw that out.
Later,
Mike Carron
Team 343
Tempest Fugit
Revisit: No. of Inventor Licenses - Great FREE alternative! Stu Bloom Inventor 1 15-10-2003 01:20
Autodesk Inventor Award 2002 Digo Inventor 1 24-03-2002 12:07
Inventor drawings of parts from kit patrickrd Inventor 1 11-01-2002 14:16
Inventor and Virtual Kit of Parts Torchin Inventor 1 09-01-2002 09:59
AutoCAD, Inventor, or Other D.J. Fluck General Forum 23 31-12-2001 08:59
