Go to Post remember to keep this simple but yet complex everyone - Team#2057-Vegas [more]
Unread 05-03-2012, 04:36
Francis115 Francis115 is offline
AKA: Daniel
FRC #3481 (Bronc Botz)
Team Role: CAD
Francis115 is an unknown quantity at this point
#35 Sprocket on CIM Motor
Are there any #35 Sprocket series sprockets that I can mount directly on a 0.313" CIM Motor? If no, how can I mount one? Thanks!
Unread 05-03-2012, 04:40
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: #35 Sprocket on CIM Motor
This year Team 2470 drilled a hole into the center of a CIMple box shaft, then put the CIM shaft in the CIMple box shaft. From there we drilled a hole through both the CIM and CIMple box shafts to put a size 8 screw in a bolted it down.
From here we were able to mount a #35 sprocket on the end. I'm sure there are many different ways to do it but we found this way the quickest and easiest.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 05-03-2012, 06:34
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
Thisis a great way to do it
Unread 05-03-2012, 06:35
J@GMFlint's Avatar
J@GMFlint J@GMFlint is offline
FRC #1243 (Dragons)
J@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond reputeJ@GMFlint has a reputation beyond repute
Make a bushing from 1/2" shaft, about 1-1.25" long bore the center to .313 / 8mm & broach a keyway for the CIM- (3/32" if you don't have a metric broach should work). Then put a hole through the bushing for the set screw from the sprocket to go through the bushing and lock onto the key, blue loctite in place. We've done this many times over the years with #35B10 sprockets.
Hope this helps.
14th Season Leading and Mentoring Great Students!!
FINALIST 2014 GLBRD- Thanks 5281 & 2145
Qtr-Finalist 2014 Bedford District
Qtr-Finalist 2014 Kettering District- (Which way was the robot s'posed to be facing...?!)
FINALIST 2011 Kettering District- God work 494 & 1684- great elim. debut Chimera's!
WINNER! 2010 West Michigan District- Awesome job 3357 & 2054!
WINNER! 2004 West Michigan Regional
2004 Rookie All-Star & Highest Rookie Seed Pittsburgh Rgnl; Rookie Inspiration & Highest Rookie Seed West Michigan Rgnl (3rd)
2007 Semi-Finalist MWR
2008 Finalist MWR - Thanks 111 & 1504 Judges Award MWR
2010 Semi-Finalist Kettering District - Thanks 1, & our friends 2337
Unread 05-03-2012, 08:52
45Auto's Avatar
45Auto 45Auto is offline
FRC #2992
45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future
Make an adapters from 8mm/2mm key to .500"/.125" key, then use a 1/2" bore sprocket.
Or buy them already made here:
http://www.andymark.com/product-p/am-0472.htm
We made some similar, but didn't run the 1/8" key slot all the way across because of the thin wall.
2007 - Rookie All Star - Bayou Regional (1858 - Tyborgs)
2009 - Rookie All Star - Bayou Regional (2992 -Prometheus)
2010 - Champions - Bayou Regional (2992 -Prometheus)
2012 - Finalist - Bayou Regional (2992 - Prometheus)
team2992.com/design.php
Unread 05-03-2012, 13:46
AKA: Daniel
Team Role: CAD
Thank you for all the replies! I might use jsasaki's suggestion, the 8mm key hub, and just attach a #35 sprocket.
Unread 05-03-2012, 14:23
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
I almost bought one of these:
http://www.electricscooterparts.com/sprockets.html#35
But figured with shipping time, we'd go with belt drive and boring out the sprockets from Gates.
