Go to Post "Mentors Only Work When Being Calibrated". - Calvin Hartley [more]
Unread 05-03-2012, 16:54
Team1605 Team1605 is offline
FRC #1605
Team1605 is an unknown quantity at this point
Waiting to connect to OTA command server
I am having troubles while deploying code to crio from netbeans.
my output displays:
init:
init:
Deleting directory C:\Users\GHCI\Documents\NetBeansProjects\Team1605\ build
Deleting directory C:\Users\GHCI\Documents\NetBeansProjects\Team1605\ suite
Deleting directory C:\Users\GHCI\Documents\NetBeansProjects\Team1605\ j2meclasses
clean:
Created dir: C:\Users\GHCI\Documents\NetBeansProjects\Team1605\ build
Compiling 3 source files to C:\Users\GHCI\Documents\NetBeansProjects\Team1605\ build
compile:
Created dir: C:\Users\GHCI\Documents\NetBeansProjects\Team1605\ j2meclasses
preverify:
Created dir: C:\Users\GHCI\Documents\NetBeansProjects\Team1605\ suite
Building jar: C:\Users\GHCI\Documents\NetBeansProjects\Team1605\ suite\Team1605_1.0.0.jar
jar-app:
CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes
CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt
CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods
[translating suite image [closed: false, parent: squawk] ...]
### Excluding compile: com.sun.squawk.Method::getParameterTypes
### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt
[Including resource: META-INF/MANIFEST.MF]
Romizer processed 98 classes and generated 4 files.
Expanding: C:\Users\GHCI\Documents\NetBeansProjects\Team1605\ suite\Team1605_1.0.0.jar into C:\Users\GHCI\Documents\NetBeansProjects\Team1605\ suite
Moving 1 file to C:\Users\GHCI\Documents\NetBeansProjects\Team1605\ suite
Deleting: C:\Users\GHCI\Documents\NetBeansProjects\Team1605\ image.suite.api
Host OS: Windows 7 6.1, 6.1
Host JVM: Java HotSpot(TM) Client VM 22.1-b02
Target IP: 10.16.5.2
Network interfaces on host:
Marvell Yukon 88E8040 PCI-E Fast Ethernet Controller: address: 10.16.5.5 netmask: 255.255.255.0 <--- on robot's subnet
Connecting FTP @10.16.5.2
upgrade:
Sending local file image.suite
flashapp:
deploy:
init:
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 11s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 12s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 13s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 14s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 15s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 16s
[cRIO] task 0x28c9890 (FTP Server Connection Thread) deleted: errno=0 (0) status=0 (0)
[cRIO] task 0x2b8fff8 (FTP Server Connection Thread) deleted: errno=0 (0) status=0 (0)
[cRIO] task 0x2814780 (FTP Server Connection Thread) deleted: errno=0 (0) status=0 (0)
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 17s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 18s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 19s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 20s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 21s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 22s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 23s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 24s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 25s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 26s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 27s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 28s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 29s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 30s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 31s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 32s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 33s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 34s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 35s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 36s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 37s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 38s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 39s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 40s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 41s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 42s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 43s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 44s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 45s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 46s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 47s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 48s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 49s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 50s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 51s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 52s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 53s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 54s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 55s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 56s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 57s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 58s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 59s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 60s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 61s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 62s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 63s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 64s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 65s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 66s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 67s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 68s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 69s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 70s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 71s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 72s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 73s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 74s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 75s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 76s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 77s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 78s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 79s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 80s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 81s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 82s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 83s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 84s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 85s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 86s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 87s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 88s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 89s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 90s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 91s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 92s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 93s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 94s
[cRIO] task 0x281f4f0 (FTP Server Connection Thread) deleted: errno=0 (0) status=0 (0)
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 95s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 96s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 97s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 98s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 99s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 100s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 101s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 102s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 103s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 104s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 105s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 106s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 107s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 108s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 109s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 110s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 111s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 112s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 113s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 114s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 115s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 116s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 117s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 118s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 119s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 120s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 121s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 122s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 123s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 124s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 125s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 126s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 127s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 128s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 129s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 130s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 131s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 132s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 133s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 134s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 135s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 136s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 137s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 138s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 139s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 140s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 141s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 142s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 143s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 144s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 145s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 146s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 147s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 148s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 149s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 150s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 151s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 152s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 153s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 154s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 155s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 156s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 157s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 158s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 159s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 160s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 161s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 162s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 163s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 164s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 165s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 166s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 167s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 168s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 169s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 170s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 171s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 172s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 173s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 174s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 175s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 176s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 177s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 178s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 179s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 180s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 181s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 182s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 183s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 184s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 185s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 186s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 187s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 188s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 189s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 190s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 191s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 192s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 193s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 194s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 195s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 196s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 197s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 198s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 199s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 200s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 201s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 202s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 203s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 204s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 205s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 206s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 207s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 208s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 209s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 210s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 211s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 212s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 213s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 214s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 215s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 216s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 217s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 218s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 219s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 220s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 221s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 222s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 223s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 224s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 225s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 226s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 227s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 228s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 229s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 230s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 231s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 232s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 233s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 234s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 235s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 236s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 237s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 238s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 239s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 240s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 241s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 242s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 243s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 244s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 245s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 246s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 247s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 248s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 249s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 250s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 251s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 252s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 253s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 254s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 255s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 256s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 257s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 258s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 259s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 260s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 261s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 262s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 263s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 264s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 265s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 266s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 267s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 268s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 269s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 270s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 271s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 272s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 273s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 274s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 275s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 276s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 277s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 278s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 279s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 280s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 281s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 282s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 283s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 284s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 285s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 286s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 287s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 288s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 289s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 290s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 291s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 292s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 293s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 294s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 295s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 296s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 297s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 298s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 299s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 300s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 301s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 302s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 303s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 304s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 305s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 306s
Waiting to connect to OTA command server of 10.16.5.2:8001 for past 307s
Unread 05-03-2012, 19:08
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: Waiting to connect to OTA command server
First thing I would try would be to create an exception for NetBeans through the computer's firewall. Failing that, try disabling the firewall entirely.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 06-03-2012, 07:26
neal's Avatar
neal neal is offline
Neal
FRC #1777 (Viking Robotics)
neal is an unknown quantity at this point
I remember seeing this last year, and I'm sure it was just a simple fix like rebooting the cRIO and the computer.
Unread 06-03-2012, 07:30
I got rid of it by resetting the cRIO.
Unread 06-03-2012, 09:01
dbeckwith's Avatar
dbeckwith dbeckwith is offline
Lead Programmer
AKA: Daniel Beckwith
FRC #3205 (The Patriots)
dbeckwith is an unknown quantity at this point
I believe this problem was fixed here: http://www.chiefdelphi.com/forums/sh...d.php?t=103920
q = (2*b) | ~(2*b);
if (life.getLemons() != null) this.lemonade = new Drink(life.getLemons());
else throw new NoLemonsException("What now?");
