Go to Post When more STEM teams exist outside schools than in them, that will be one indication that a true cultural change has occurred. - gblake [more]
Unread 03-05-2012, 07:12 PM
Blondie3160 Blondie3160 is offline
FRC #3160 (F.R.O.G.)
Blondie3160 is an unknown quantity at this point
Sheet metal and Electrics
Hey! Has anyone ran into a problem with putting electrical units on sheet metel??? We'd like to know soon. Thanks!!!
Blondie3160
Unread 03-05-2012, 07:13 PM
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: Sheet metal and Electrics
We always mount them on lexan and have no problems.
Unread 03-05-2012, 07:16 PM
But can we do it on sheet metal?
Blondie3160
Unread 03-05-2012, 07:18 PM
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
We mount all of our electronics on sheet metal. We have not run into any problems using 1/16 aluminum, and just punching and drilling holes in it.
Unread 03-05-2012, 07:22 PM
You can, but you increase the risk of shorting out your electronics. I strongly recommend mounting your electronics on a non conductive surface.
If you do mount it on sheet metal, double and triple check the common faults:
  1. Check your crimps with a tug test.
  2. Insulate your cRIO from the sheet metal, and be sure to use an insulated mounting method.
  3. Insulate your camera's mounting post.
  4. Seriously, re-check your crimps. I mean it.
  5. Make sure you have no exposed copper. This may mean trimming your wires to length.
  6. How are those crimps looking?
Unread 03-05-2012, 07:23 PM
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Just be careful. Remember the cRIO and the camera need to be electrically isolated from the frame of your robot. The ground reference (negative terminal of the battery) can't be shorted to the metal frame of your robot or you will fail inspection.
HTH
Unread 03-05-2012, 07:40 PM
philso philso is offline
FRC #2587
Our robot has Victors mounted on the sheet metal chassis. I noticed that one of the mounting screws is very close to one of the motor terminals so I had the students change to using nylon screws. The nylon screws have held up through one Regional. Other teams are using cable ties through a pair of holes. We would do that too but would have to drill more holes in the sheet metal.
Unread 03-05-2012, 07:56 PM
James Kuszmaul James Kuszmaul is online now
NEFIRST CSA
FRC #0971 (Spartan Robotics)
James Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud of
Nylon bolts, PEM nuts, and plastic washers seem to work fine for most of the electronics.
Unread 03-05-2012, 08:59 PM
KennyLives's Avatar
KennyLives KennyLives is offline
Grand Vizier of Pneumadynes
AKA: Kenneth Prouty
FRC #2122 (Team Tators)
KennyLives is an unknown quantity at this point
We always make an electrical box out of sheet metal. Works great.
No leaks. Ever.
Unread 03-05-2012, 09:17 PM
DonRotolo's Avatar
Back to humble
FRC #0832
Metal is legal, even if not always optimal as others have noted. Most components are electrically isolated when properly mounted (the cRio being a notable exception)
If running wires through drilled holes, be sure to have some way to prevent the wires from damage from the sharp edges.
Unread 03-05-2012, 09:21 PM
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
But more dangerous to add/change wiring while still hot! ;o)
Unread 03-05-2012, 10:07 PM
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We've been using wood for our electronics enclosure for the past several years...it just seems to be the natural material. It's easy to screw the components to it, you don't have to worry about shorts, the extra weight isn't a problem since we put it down low, it's easy to work with plywood, etc. I guess there are good reasons to use something else, but I can't think of them....
Then again, we made our chassis out of steel again this year, so I may be totally out to lunch.
Unread 03-06-2012, 01:35 AM
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I strongly recommend against mounting electronics to sheet metal.
With all the things that can go wrong on a FIRST robot, why wouldn't you take all the easy precautions you can?
Mount on lexan, corrugated polycarb, foamed pvc, plywood, composite (not carbon fiber, as it conducts). Use nylon bolts with nylon thumb nuts. Run wiring in convolute, anti abrasion sleeve, or plastic channel where possible. Avoid running wires inside inaccessible places like towers, arms, etc.
