Go to Post Its always good to read the rules yourself rather than listen to "word of mouth" rules. - Killraine [more]
Unread 05-03-2012, 23:13
hannigan hannigan is offline
FRC #2264
hannigan is an unknown quantity at this point
Good Battery Chargers
Hi,
We are going to our regionals this weekend, but we only have one battery charger. (We lost the other one). I was hoping to buy one before the competition so we could charge more batteries, but I need to get one from a store and not online because we need it in three days. I found one at walmart. Does this charger look okay http://www.walmart.com/ip/Schumacher...arger/15140194 or is there a better one from an automotive one that I could get. Are there any rules against certain battery chargers?
Thanks,
Emily
Unread 05-03-2012, 23:31
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Good Battery Chargers
A good cheap single charger many teams use: http://www.amazon.com/Schumacher-SC-...08226&sr= 1-6
Also andymark has a nice 3 bank charger: http://www.andymark.com/Battery-Char...-p/am-2026.htm
I am not sure about the charger you linked, in general you want something that is smart [auto shut off] and maxes at 6amps.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 06-03-2012, 00:55
Originally Posted by hannigan View Post
It's hard to tell from that link. You want a charger that is capable of properly charging an AGM (Absorbed Glass Mat) technology battery, like the ones used in FRC.
Just found this link. Claims it will handle AGM batteries:
http://www.amazon.com/Schumacher-XC6.../dp/B004EIBX00
Unread 06-03-2012, 19:26
hannigan,
I agree that this charger is a good choice for charging our batteries. It is nearly identical in specs to the KOP charger.
Unread 06-03-2012, 21:15
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Hi,
Thanks,
Emily
We got three of these last year and they charged our batteries fine.
Unread 06-03-2012, 21:26
littlejimmy1058's Avatar
littlejimmy1058 littlejimmy1058 is offline
Safety Captain
AKA: Daniel Browne
FRC #1058 (PVC Pirates)
littlejimmy1058 is an unknown quantity at this point
I agree with Mk. 62. We have two types of chargers and this one is one of them, the other being the KOP charger.
Captain of Safety for Team 1058, The PVC Pirates
"Lunacy will be played on a 27-by-54 foot field..."
Awards-
2012-Chairman's Award (Granite State Regional)
Unread 06-03-2012, 21:40
Billfred's Avatar
Billfred Billfred is offline
Hi,
Thanks,
Emily
We bought two very similar ones (ours have the same specs and type of case, but in gray) last year and have had zero trouble with them. All we did was clip the stock clips off and replace them with an Anderson connector so it mates right up with the robot batteries. We normally charge at 2A overnight and around the shop, 6A during competitions. Great deal.
Unread 07-03-2012, 00:02
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
One thing that I will comment on here that Billfred touched on is not using the stock connectors that come on the charger. Normally these chargers come with alligator clips which are ok to use with automotive or marine batteries that have large exposed terminals for a couple of times where damage that can occur will be minimal, but not for our use. Because we continually use the chargers with our batteries for competition, we do not have exposed terminals the charger connects to, but soft contacts within the Anderson power pole connectors. If you use alligator clips or other style "clamps" or "clips" to connect your charger to the battery, you will damage your battery. Every time an alligator clip is attached to the Anderson half connectors leads, it scratches them and mars the smooth contacts finish. When you then try to use this half connector with the connector on the robot, you will not get full seating between the two contacts and will increase your resistance between your robot and battery. Increased resistance leads to high drops in power transferred to the robot, increased heat at the connector points, and failure can occur. I have seen some major damage on robots where the Anderson half connectors fused because of the heat generated from the poor connection between metal contacts.
You can easily avoid this problem though by splicing in Anderson half connectors on your chargers in place of the stock clamps that may be on there. The Anderson's are designed to mate together firmly and always used with two half connectors. Save yourself the cost and hassle of replacing a damaged battery (or worse) later by using proper connectors now.
-Michael Dessingue
Unread 07-03-2012, 00:06
Mk.32's Avatar
AKA: Mark
So who is this Mk.62 you speak of
