Go to Post Don't worry so much about the wording of the rules but the intent of the rules. - Greg Needel [more]
Unread 05-03-2012, 23:52
carrillo694's Avatar
carrillo694 carrillo694 is offline
Alex Carrillo
FRC #0694 (Stuypulse)
carrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the rough
Problems with tuning shooters using AM basketballs on Practice Field?
I heard about 20 minutes in to this podcast that teams that tuned their shooters using their own AndyMark basketballs on the practice field encountered tuning issues when they used competition basketballs on the real field.
A speaker in the podcast states that, while their shooter worked perfectly with the balls they used on the practice field, it consistently overshot the hoop when they played on the actual field with the competition balls. The other commentators confirmed this phenomenon as being real.
Have any other teams encountered this issue at any of the past few regionals?
Unread 06-03-2012, 00:22
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: Problems with tuning shooters using AM basketballs on Practice Field?
I can confirm that we had balls in our shop of varying densities and wear and tear. A new ball would shoot a good 5 feet higher than an old worn out one. Regardless of this, our plan is to re-calibrate our shooter when we get to the event, with whatever kind of ball they have there.
Unread 06-03-2012, 05:56
GaryVoshol's Avatar
Cogito ergo arbitro
You might also note that the practice field tends to be the graveyard for balls that are killed on the competition field.
(since 2004)
Unread 06-03-2012, 07:26
Tommy F.'s Avatar
Tommy F. Tommy F. is offline
Yeah! Collages!
AKA: 7h0m45
FRC #1985 (Robohawks)
Tommy F. is just really niceTommy F. is just really niceTommy F. is just really niceTommy F. is just really nice
We were having this problem as well at GKC. In practice we would tune our PID setpoints until the ball would make it into the hoop every time, and then when we went on the competition field our balls would overshoot.
We were also using one of our first balls that has suffered some wear and tear. I'll have to remember to bring a newer ball with us to our next regional.
FTC 289, 290 & 291 :: FRC 1985
2013 St. Louis Regional Semi-Finalist (with 3411 and 4330), Industrial Design Award
2013 Queen City Regional Winner (with 379 and 447)
Unread 06-03-2012, 08:04
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We noticed our shooter accuracy getting worse as the regional progressed...one of the possible reasons is the condition of the balls becoming more different as they are used longer. But we have other things to worry about too, like our shooter getting wonked when the robot falls off the bridge (which only happened about 4 or 5 times)
This game has some good challenges, excellent job GDC!
Unread 06-03-2012, 08:16
Jared Russell's Avatar
Jared Russell Jared Russell is online now
Taking a year (mostly) off
The balls on the field were definitely much denser than any of the balls we had been practicing with. We even reserved some brand new balls for practice on the final days of build season, and the balls at the event still flew much further. I do not have a great explanation as for why, since all balls with the FIRST logo are apparently from the same batch. I will say that if you bought balls directly from Gopher Sports, the FIRST balls have both a different density and a different surface finish.
As the event went on, balls were worn/damaged but still (in my opinion) seemed to shoot further than our shop balls.
It's all part of the challenge. Some types of shooters are more susceptible to amplifying ball variation than others. At least one team - 1218 - rigged up a sensor to measure ball squishiness and fed the result to their shooter speed control system.
The most straightforward thing you can probably do about it is make it easy to adjust your shooter to the variation. Use a configuration file to read in new speed setpoints without requiring recompiling code. Or give your drivers a trim wheel to add or subtract from a nominal motor/wheel speed. You will probably get between 1 and 5 practice matches at your event. You want to be able to dial it in in that time!
Unread 06-03-2012, 08:34
MrForbes's Avatar
AKA: Jim
We have a trim control for ours. But I still think our shooter speed control algorithm is flaky, on top of everything else....
Unread 06-03-2012, 08:42
Ryan Caldwell's Avatar
Ryan Caldwell Ryan Caldwell is offline
217 Alum, 2851 Founder, 469 Mentor
FRC #0469
Ryan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant future
Send a message via AIM to Ryan Caldwell
we ran into the same thing
we are using single wheel shooter with a stationary pinch bar to compress the ball into the spinning wheel makes for lots of backspin. The video link is what we found with the worn balls vs. new balls. the issue seams to be the compression reaction more than the surface wear. the new balls will take effort to move the air out of while used balls have lots of little nicks and cracks for the air to escape out of thus the force to compress is much less.
Our solution was to reduce the amount of pinch on the ball this limited our distance but greatly increased our consistency from one ball to the next.
http://www.youtube.com/watch?v=4EueP...eature=channel
Insane and Insight are just about the same thing if you squint and turn your head ever so slightly
Unread 06-03-2012, 08:55
MrForbes's Avatar
AKA: Jim
That sounds like a good explanation of what's happening.
Unread 06-03-2012, 08:57
JABot67 JABot67 is offline
Unregistered User
AKA: John Bottenberg
FRC #2930 (Sonic Squirrels)
JABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond reputeJABot67 has a reputation beyond repute
This.
We had a consistent shooter in our shop, then decided to try to increase our range by increasing the compression. This greatly reduced our accuracy. We bought a new ball and tried to shoot it; it sailed a couple feet higher than all the old balls we were using. We concluded that the added compression was hurting us.
John Bottenberg - University of Michigan '14 - Microsoft
FLL Team "Dark Matter": 2003-2005
Robofest Team "Dark Matter": 2005-2008
Team 67 Programmer: 2007-2010
Team 3322 Programming Mentor: 2012-2014
Team 2930 Engineering Mentor: 2015-????
Unread 06-03-2012, 08:58
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
We've been using an open-ended voltage control (same as 2006) for our 5-roller shooter and were very consistent throughout GSR. Even when fresh balls were put out on the field during eliminations our hybrid was as consistent as before. FWIW I think we're ranked 20-something in Hybrid OPR.
Our program essentially does this:
shooter_speed = 11/system_voltage
We tried a PID loop but couldn't ever get it to behave the way we wanted it to. The issues being that there are huge changes in friction and system inertia when a ball is engaged with the shooter, and our shooter system is slow low-inertia that the PID loop is unstable when under no load no matter how much we tuned it.
Unread 06-03-2012, 09:01
MrForbes's Avatar
AKA: Jim
I'm thinking that this is a good solution to part of our problem. I wonder what the odds of us being able to implement new code on Thursday (AZ regional) are?
Unread 06-03-2012, 09:12
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
So a gain that made it stable with no load did not compensate for the change in load when compressing a ball? Then raising the gain to help made it oscillate under no load? We might have the same problem... what motors do you use?
For teams incorporating a compensation factor - was the factor a simple constant or a constant multiplied by V or maybe V squared?
TIA
Unread 06-03-2012, 09:17
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Very high I'd bet. Our student programmed disabled the PID loop and added the voltage control in 10 minutes. I'm no expert, but it seemed very simple.
TIA
I believe that's what was happening to us. We're using two RS550s for our shooter. PIDs might work better for other teams with higher-inertia shooters. Our shooter consists of five 4" long rollers made from 0.065" walled aluminum tube, there is hardly any mass/inertia there. We couldn't even get a stable no-load PID loop, it was causing some seriously scary motor arcing.
Unread 06-03-2012, 09:21
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Our shooter uses 2 AM 8" FIRST wheels driven by 2 FP 0673 motors and 2 AM 9015 motors. I was hoping having a lot of torque to spare (the motors barely get warm to the touch) might make it more reliable/tunable - we'll see I reckon.
