Go to Post Belts are a fine way of transferring power in a robot. Like chains, gears, drive shafts, viscous couplings or any other means of transmission they require some care and attention on you're part. But no one said this robot stuff was going to be a cake walk. - Andy A. [more]
View Poll Results: Was this useful?
Yes, it was! It helped point out diamonds in the rough 109 70.32%
No, its numbers generally did not correspond to robot's actual on-field performance 46 29.68%
Voters: 155. You may not vote on this poll
Thread Tools Rating: Thread Rating: 32 votes, 4.88 average. Display Modes
  #241   Spotlight this post!
Unread 05-03-2012, 23:59
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Re: Easy to use Offensive Power Rankings (OPR) program for mid-regional scouting
I'm having the same issue as Mr. Bill, but on XP x32 (I know, antiquated, right?).
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
  #242   Spotlight this post!
Unread 06-03-2012, 00:38
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
I just tried installing the MS Visual C++ 2010 as well, and that didn't fix it either.
Now this is getting odd!
OK, it's a few minutes later now.
I just copied the MSVCP100.dll file from system32 into the folder with OPRNet.
I now get a different error. See the attached image.
I read a few message on the net saying something about linking the dll's statically. Does that make sense to you? This is way out of my league.
Name:	OPRNet v19 error.jpg
  #243   Spotlight this post!
Unread 06-03-2012, 06:29
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Ah, I must have messed up my project settings. I changed its directory on my computer so I could get it in source control, and I must have forgotten to move something else or change a setting.
Edit: Whoops, I'm so used to developing on VS2008 I forgot I've moved to 2010 at home. Ok, so you need these runtimes: http://www.microsoft.com/download/en...s.aspx?id=5555
  #244   Spotlight this post!
Unread 06-03-2012, 06:39
Bongle's Avatar
Here's v20. I made it so the overall OPR is also given the coopertition adjustment (coopertition points * 5, assuming that CPs are points you could have gotten if your alliance assigned you to a different bridge), and did a clean-and-build to attempt to fix the 0xc000007b errors people are getting.
  #245   Spotlight this post!
Unread 06-03-2012, 10:05
billbo911's Avatar
Yep, working like a champ now!
Bongle,
Can I ask you a favor? Can you please make a single post describing all the command line options? I've been using this awesome little tool for a few seasons now and really love it. The problem is, my PC took a dive last fall and I lost all my batch files I used as templates. So, I need to start from scratch and I am, well, a bit lazy and don't want to read through 16+ pages of posts to find all the tricks I used to generate the data I used to use.
Thanks!
  #246   Spotlight this post!
Unread 06-03-2012, 10:25
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
It says i cant run because im missing the MSVCP100.dll and I cant find that .dll
1592(Student and Mentor) 2007-Present
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
  #247   Spotlight this post!
Unread 06-03-2012, 10:29
Bongle's Avatar
Bongle,
Thanks!
Here's the bat file I used for the week 1 regionals:
oprnet gg 2012 bridge r q > allopr-bridge.txt
oprnet stx 2012 bridge r q >> allopr-bridge.txt
oprnet sdc 2012 bridge r q >> allopr-bridge.txt
oprnet nh 2012 bridge r q >> allopr-bridge.txt
oprnet kc 2012 bridge r q >> allopr-bridge.txt
oprnet tn 2012 bridge r q >> allopr-bridge.txt
oprnet migl 2012 bridge r q >> allopr-bridge.txt
oprnet pah 2012 bridge r q >> allopr-bridge.txt
oprnet gg 2012 teleop r q > allopr-teleop.txt
oprnet stx 2012 teleop r q >> allopr-teleop.txt
oprnet sdc 2012 teleop r q >> allopr-teleop.txt
oprnet nh 2012 teleop r q >> allopr-teleop.txt
oprnet kc 2012 teleop r q >> allopr-teleop.txt
oprnet tn 2012 teleop r q >> allopr-teleop.txt
oprnet migl 2012 teleop r q >> allopr-teleop.txt
oprnet pah 2012 teleop r q >> allopr-teleop.txt
oprnet gg 2012 hybrid r q > allopr-hybrid.txt
oprnet stx 2012 hybrid r q >> allopr-hybrid.txt
oprnet sdc 2012 hybrid r q >> allopr-hybrid.txt
oprnet nh 2012 hybrid r q >> allopr-hybrid.txt
oprnet kc 2012 hybrid r q >> allopr-hybrid.txt
oprnet tn 2012 hybrid r q >> allopr-hybrid.txt
oprnet migl 2012 hybrid r q >> allopr-hybrid.txt
oprnet pah 2012 hybrid r q >> allopr-hybrid.txt
Let's take one line:
"oprnet nh 2012 hybrid r q >> allopr-hybrid.txt"
Broken down:
oprnet - you need this part to start the program
nh - indicates you care about the new hampshire regional
2012 - indicates you want results for 2012
hybrid - indicates the statistic you want to print (other options for 2012: opr, teleop, hybrid, bridge)
r - sort teams by ranking (as opposed to 't', which sorts them by team number)
q - quiet mode: makes it not print out status data. Also changes the output format so it's easier to copy/paste into excel. If you want loud mode from the command line for whatever reason, just omit the q.
>> - tells DOS to append all output from oprnet to a text file. The single greater-than ('>') tells it to clear out the file and start over.
allopr-hybrid.txt - which file you want to output to.
The q is optional, and the ">> blah.txt", being a DOS command, is also optional. If you don't have the ">> blah.txt", it'll just spit to your command-line window.
Note that because I'm lazy and because I doubt there's that much use nowadays of the more esoteric parameters like SAA, PM, or DPR, I don't really support them and if the app crashes when you try to use one, I am not that bothered. In 2013, I'm likely to not care very much if the bridge/teleop/hybrid feature gets broken as well.
  #248   Spotlight this post!
Unread 06-03-2012, 11:35
billbo911's Avatar
Dodar,
First, follow the link in Bongle's message above and add the Visual 2010 runtimes. Then download and run his v.20 and you should find it works again.
Broken down:
Bongle,
As always, you have exceeded my expectations. Thanks for getting exactly what I am looking for spelled out so quickly!!
  #249   Spotlight this post!
Unread 06-03-2012, 12:45
The Lucas's Avatar
CaMOElot, it is a silly place
Great work as always.
Where do get the data from? FMS Twitter Feed? FRCspy?
Robot Inspector
  #250   Spotlight this post!
Unread 06-03-2012, 14:26
Bongle's Avatar
USFirst, with TheBlueAlliance as a backup*. The bridge/hybrid/teleop stuff requires the USFirst team rankings page to be up.
*I haven't actually tested the TBA backup code in a while, I'm not sure it still works since it is at least 2 years old.
  #251   Spotlight this post!
Unread 06-03-2012, 14:28
Basel A's Avatar
AKA: @BaselThe2nd
This is awesome. Thank you!
-Paul Copioli
  #252   Spotlight this post!
Unread 07-03-2012, 14:21
Bongle's Avatar
I've been fairly googlish with my posting of source code, but here's v20's. It's fairly hackish code because I keep patching it with new features each year that I didn't originally envision, so please don't judge me on the quality.
  #253   Spotlight this post!
Unread 07-03-2012, 14:45
source code ... here's v20's.
Just curious: what are you using LU decomposition for ?
  #254   Spotlight this post!
Unread 07-03-2012, 15:11
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Bongle,
I might be doing this wrong, but I seem to be having a problem; whenever I submit a response to the final query (i.e. 'r' for sort teams by rank), it creates two temporary files, then shuts down. A couple years ago, when I fooled around with one of your earlier versions, it worked fine. Now however, apparently I'm doing something wrong. Any idea what I've done?
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
  #255   Spotlight this post!
Unread 07-03-2012, 17:32
Bongle's Avatar
Originally Posted by RogerR View Post
Bongle,
If you rename the temporary files to .html and try to view them in a browser, they should just be the FIRST results pages. If they aren't, or they look stylistically different than this one, then the parser that extracts the scores might be having trouble.
I believe that's the technique the matrix solving library I use (JAMA) uses. I don't know too many details about it.
Offensive Power Ranking Calculations Greg Marra General Forum 4 18-03-2009 22:03
Offensive Power Rankings for 2008 Bongle General Forum 166 18-05-2008 15:05
Offensive+Defensive Power Rankings BornaE General Forum 4 05-04-2008 01:33
2006 Offensive Power Ratings sw293 General Forum 16 10-05-2006 17:04
(CURIE) Let's make this Easy for all of us. [scouting] 157#1Driver Championship Event 13 22-04-2002 08:56
