Go to Post I personally need all the limbs and eyeballs I currently have, and I assume other feel the same way. - bfk [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
  #76   Spotlight this post!
Unread 27-02-2012, 11:28
Re: Tips from a veteran Robot Inspector
Quantity is limited to the most recent list.
So the first two CIMs are free.
  #77   Spotlight this post!
Unread 27-02-2012, 11:46
Remember that the GDC in the Q&A covers items that are previous KOP that have been modified prior to the 2012 season.
  #78   Spotlight this post!
Unread 04-03-2012, 16:44
Now that week 1 is under the bridge (pun intended) let us take a look at some additional items.
This weekend it seems that bumpers continue to be an issue. Regardless of previous year's rules, the minimum bumper segment must be 8" long and be supported by robot frame. The ends may not extend past robot frame and be unsupported. In other words, if you have constructed your robot frame to be 6" wide on either side of a ball handler opening in your frame, this is an illegal design. The frame and bumper must be a minimum of 8" and the bumper must be fully supported by the frame (except with certain exceptions listed in R33) You cannot have a 6" frame segment with an 8" bumper segment mounted to it allowing the bumper to extend beyond the frame.
Numbers on the bumpers must be in four places and four only. The team numbers must not be segmented or split across an opening or across two bumper segments. The GDC has ruled on this and is very clear in how teams are to implement the rule and how inspectors are to judge the bumper design.
While inspectors will not rule on appendage usage, we will inspect for the distance outside the frame that any appendage can travel during a match. If you appendage is capable of extending beyond 14 inches and has some limit in place (either mechanical stops or software) then they will check that during inspection as well.
Rev C of the Inspection Checklist was issued on Tuesday. This will be the version used at events except if an updated checklist is issued.
I would like to remind everyone that modification of motors is only allowed for very specific reasons...
R49
Motors, servos, and electric solenoids used on the Robot shall not be modified in any way, except as follows:
A. The mounting brackets and/or output shaft/interface may be modified to facilitate the physical connection of the motor to the Robot and actuated part.
B. The electrical input leads may be trimmed to length as necessary.
C. The locking pins on the window motors (PN 262100-3030 and 262100-3040) may be removed.
D. The connector housings on the window motors (PN 262100-3030 and262100-3040) may be modified to facilitate lead connections.
Please note that this does not allow modifications to motors or integral transmissions even if the manufacturer supplies a mod kit. It does not allow the removal of integral transmissions to use the motor only.
I hope all teams participating in Week Two events have a great time.
  #79   Spotlight this post!
Unread 04-03-2012, 16:54
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
I don't think that the four and four times only number can be stressed enough. I saw a team at Gull Lake in Eliminations competing with the number five times.
  #80   Spotlight this post!
Unread 04-03-2012, 17:13
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
I'll add what I saw at the Smoky Mountains Regional.
I saw several breakers that were hard to get to. One team had their breaker inside a plexiglass box. I asked them how they turned on their bot and they told me they remove the front bumper, remove the two screws holding the lid down and then turn on/off the switch. I got them to put in a hole in the side of the box.
Also, please go over your pneumatic schematic and be sure everything is in it's place. Just saying.
Also, I had fun at SMR. Ed was great to work for.
FYI, only use one tag on your bagged robot
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
  #81   Spotlight this post!
Unread 05-03-2012, 17:30
There is a reason I have Ed as a division lead at Champs.
  #82   Spotlight this post!
Unread 05-03-2012, 21:36
sandiegodan's Avatar
sandiegodan sandiegodan is offline
FTC Mentor, FRC Inspector
AKA: Dan Glenn
FTC #10092 (Green.Griffins;)
sandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to allsandiegodan is a name known to all
I had a question on this as we had lots of issues with this in San Diego this past weekend. Since there is no 8" minimum frame requirement on it's own, it would make sense to me that if an 8" bumper carried it's own continuous metal backing and could be securely attached to the frame, that would constitute a legal system? Providing it met weight of course.
We were specifically making teams extend their frames causing substantial rework and missed matches. Not to mention modifications to ball retrieval systems. I will be inspecting at 3 more competitions and I'd like to offer some better alternatives to teams for being in compliance and ensure consistency throughout the competition season.
Thank you,
Dan Glenn
2015-16 FRC Chairman, San Diego Regional Planning Committee
2016 FRC Inspector, Orange County (LRI), Los Angeles, Carson Division
2015 FRC Inspector, Inland Empire (LRI), Central Valley, Los Angeles, Galileo Division
2015 FTC Mentor 10092 Green.Griffins; R&D Robotics Education
2014 FRC Inspector, Inland Empire, San Diego(LRI), Archimedes Division
2012-15 FTC Mentor Team 6565 Stuffed Dragons & 8489 Green Griffins Boys and Girls Club
2013 FRC Inspector, Central Valley, San Diego(LRI), Los Angeles, Inland Empire, Galileo Division
2012 FRC Inspector, San Diego, Los Angeles, Central Valley, Newton Division
2009-12 FRC Mentor Team 1622 Spyder Poway HS
2007-08 FRC Mentor Team 2658 Pedestrian Rancho Bernardo HS
  #83   Spotlight this post!
Unread 05-03-2012, 22:51
pfreivald's Avatar
AKA: Patrick Freivald
I do have to say, teams that attend the Rochester Rally every year (hosted by Team 1511) have a great benefit: FLR's chief inspector, the wonderful (and extremely tall) Rob Heslin gives every robot a quick once-over to make sure that the most egregious faults are identified prior to Bag and Tag. Our bumpers were good, but our pneumatics needed modification...
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #84   Spotlight this post!
Unread 06-03-2012, 00:48
Duncan Macdonald's Avatar
Duncan Macdonald Duncan Macdonald is offline
Globe Motor Fan Club
FRC #0610 (Crescent Robotics)
Duncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond repute
Send a message via MSN to Duncan Macdonald
Did the world end?
#1 thing I wish was a non issue this year.
Queen's Applied Science '13, Applied Mathematics
  #85   Spotlight this post!
Unread 06-03-2012, 00:56
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Thank you,
I inspected Alamo this weekend and we were allowing lots of ways to extend the frame, most of the time it was just an L bracket, the rules don't really define how sturdy a frame must be as long it is non-articulated. The most important part is the frame counts to your weight and isn't part of your bumper attachment system which is weighed differently, so having 6 inch of frame with 8 inch of metal backing on the bumper would change where the weight is allocated.
  #86   Spotlight this post!
Unread 06-03-2012, 05:40
GaryVoshol's Avatar
Cogito ergo arbitro
The most common method of "erasing" the 5th bumper number is to put tape over it. So they exchange one rules violation for another. Is that what we really want?
Allowable bumper materials are plywood, noodles, fabric, fasteners and optional angle reinforcements. Nothing else. Which is why the suggestion of integral metal reinforcement of the bumper itself isn't permitted.
(since 2004)
  #87   Spotlight this post!
Unread 06-03-2012, 06:55
pfreivald's Avatar
Part of me agrees, but part of me is happy that they're being (at least mostly) consistent about making sure that teams follow the rules, whatever those rules happen to be.
Team 1551
I write books, too!
  #88   Spotlight this post!
Unread 06-03-2012, 08:53
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
(emphasis mine)
Where in the rules does it say "nothing else"? [R28] mentions some things you must use (noodles, cloth), but does not say "only" or any words like that.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
  #89   Spotlight this post!
Unread 06-03-2012, 09:09
remulasce remulasce is offline
remulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to behold
[R28] begins with "Bumpers must be constructed as follows". If your intended method & materials do not follow, then it is not allowed.
Student 294: 2007-2011
Mentor 597: 2013-2015
Google SWE: 2015-
  #90   Spotlight this post!
Unread 06-03-2012, 09:17
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
The metal backing has been determined to be "fastener" in the past. The reason that a metal backing on the bumper is not considered "frame" is because it's attached to the bumper, not the robot. "Frame" must meet all robot size and weight requirements. It really starts to become a "I need to see the specific implementation" headache, and I'm dreading some of the things we are going to see at Championship with the requisite "But it passed at XXX regional" commentary.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
