Go to Post Build the wrong robot that aims well or build the right robot that can't aim.... decisions, decisions.... - Tom Bottiglieri [more]
Unread 05-01-2003, 11:56
Rick Gibbs Rick Gibbs is offline
#0145 (T-Rx)
Rick Gibbs is an unknown quantity at this point
Locking the drill motor clutch?
In previous years our tem always used a methods to lock the final ring in place to disable the clutch. I've seen several variations on the same theme - from Dr. Joes Drill Advice - to actually pinning them.
Any ideas for this year?
I don't see an obvious way to do it like previous years. Do you think the locking mechanism on the drill is sufficient?
Rick Gibbs
Unread 06-01-2003, 09:46
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
Do you mean the shifter? for the second stage?
If you rotate the first stage plastic piece 180 degrees, it automatically locks the shifter into high torque mode.
If you mean how to lock the clutch into "drill mode", we drilled and tapped a hole in the clutch housing and sent a bolt through the fixed housing into the clutch housing. That worked fine.
Andrew
Team 356
White Paper Discuss: Locking the Bosch 3360 Drill in low gear CD47-Bot Extra Discussion 4 05-08-2003 02:10
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
