Go to Post Can you restate your observation in a manner that reconciles with physics? - Madison [more]
Unread 06-03-2012, 09:26
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Problems with tuning shooters using AM basketballs on Practice Field?
Originally Posted by wireties View Post
Our shooter uses 2 AM 8" FIRST wheels driven by 2 FP 0673 motors and 2 AM 9015 motors. I was hoping having a lot of torque to spare (the motors barely get warm to the touch) might make it more reliable/tunable - we'll see I reckon.
They might be, that's considerably more torque/inertia than our shooter.
What I like best about the voltage control is that there is no tuning involved, set it once and don't worry about it after that.
Unread 06-03-2012, 09:52
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We have a single 8" kit wheel driven by a single powerful FP motor. We seem to spend a lot of time waiting for the thing to settle down, we could probably shoot a few more baskets with the simple voltage algorithm. I posted a link to this thread on our team fb page, our programmer should see it.
Ironically today he's doing his science fair project report on the feedback speed control system
Unread 06-03-2012, 09:53
pfreivald's Avatar
AKA: Patrick Freivald
We're using 2x two 8" wheels on 1/2" shafts with AM hubs driven by AndyMark motors and Andymark 3.67:1 planetary gearboxes, and our PID is quite stable -- we fed both old and brand new balls through it and it was consistent except for once in a while... The compressibility of the ball didn't seem to influence the throw much.
...I hope that pans out!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 06-03-2012, 10:04
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Could you explain to someone ignorant why controlling with voltage is so much better than PID? I would think that you want constant rpms on the shooter wheels for maximum consistency. More success with a less sophisticated control system seems a little counter-intuitive to me...
-Plutarch
Unread 06-03-2012, 10:08
MrForbes's Avatar
AKA: Jim
You're right...except that some of us seem to have built systems that are very difficult to get reliable speed control with. In that case, a consistent open loop system could work better.
Unread 06-03-2012, 10:20
wireties's Avatar
wireties wireties is online now
Principal Engineer
AKA: Keith Buchanan
PID is a good solution but it is not magic. The software is only one part of the servo system. In this case one can tune the wheel to free rotate at a selected speed but not have enough gain to recover quickly when a ball slows it down. So one might try to raise the gain. But then the higher gain might create an under-damped or oscillating condition when there is no load.
One approach is too build mechanical gain into the system by using stronger motors or storing energy in a flywheel etc. This gain would have much less phase delay and be more stable (I hope).
HTH
Unread 06-03-2012, 10:23
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
In a perfect world, a perfectly tuned super-fast PID control would be better than just about anything else. However, an open-loop voltage control scheme works well enough for what we need to do in FRC without requiring any tuning at all. This control has gotten 95 in the top 5% Hybrid OPR.
I think this is definitely a case of "the best is the enemy of good enough." At least for my team this year.
Unread 06-03-2012, 10:38
MrForbes's Avatar
AKA: Jim
interesting...we're a couple above you with closed loop! But I still think we should give open loop a try.
Unread 06-03-2012, 10:52
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
Based on this thread, we are definitely gonna have both approaches ready to go!
Unread 06-03-2012, 11:05
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Hrm, quite interesting. I don't understand the OPR completely, but it seems like it can be skewed by alliance partner performance, either up or down.
For what it's worth I'd call our autonomous 70-80% reliable, with a large amount of our misses coming from shots spaced too close together where the second ball bounces off of the first. A delay between hybrid shots will be implemented for the Hartford regional.
Unread 06-03-2012, 11:10
MrForbes's Avatar
AKA: Jim
We have a really long delay between shots, waiting for the shooter speed to adjust. Open loop could really speed up our shooting process, hopefully enough to get a few more shots off in teleop
Unread 06-03-2012, 11:26
one4robots one4robots is offline
AKA: Vince Wagner
FRC #2530 (Inconceivable)
one4robots is on a distinguished road
Smile Re: Problems with tuning shooters using AM basketballs on Practice Field?
We also have a driver enabled adjustment button. Each click of the button decreases (or increases) the voltage applied to the shooter by 1/10th of a volt. This results in a decreased (increased) RPM of ~100. So if we find we are overshooting by 5 feet, the human shooter knows to decrease 3 clicks based on data collected during practices.
The problems that are often outside of our control (like ball squishy-ness) are the most valuable learning tools! Thanks, GDC!
It's Inconceivable!
2015 Wisconsin Regional Winner - Thanks 2826 and 2062!
2014 Wisconsin Regional Semi-finalist and Alliance Captain - Thanks 167 and 4296!
2014 MSHSL Finalist and Alliance Captain - Thanks 3018 and 4607!
2013 Northern Lights Gracious Professionalism Award
2012 MRI Champions - Thanks, 3883 and 3630!
2012 MSHSL State Tournament Semi-finalist
2012 10,000 Lakes Regional Finalist
2012 10,000 Lakes Regional Delphi Engineering Excellence Award
2012 Lake Superior Regional GM Industrial Design Award
2011 Minnesota Robotics Invitational (MRI) Champions - Thanks, 2052 and 2450!
2011 Inaugural Lake Superior Regional Finalist
2011 Lake Superior Regional Judges Award
Unread 06-03-2012, 11:32
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #0020 (The Rocketeers)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
This was a HUGE problem for Team 20 this past weekend at GSR; we went from a 60% shooter in practice to a 3% shooter. Our targetting was working, but we were over shooting the hoop by 4 to 5 feet every time. Come to competition with a plan in place to account for the difference, or you will be sorry.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 06-03-2012, 11:54
Is that a written report? If so, could you ask him if he'd be willing to post it?
Unread 06-03-2012, 12:15
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Are there any teams who attended a week 1 event who didn't have an issue with this?
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
