Go to Post Theory (n.) - A mythical place where all robot designs work. - MechEng83 [more]
Unread 06-01-2003, 09:53
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Custom Circuit
Do the custom circuits have to be contained within a box like last year? I read through the rules and could not find anything on it. The sample inspection checksheet mentions it, but it looks like FIRST just copied and pasted it from last year.
- Katie
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 06-01-2003, 11:22
D.J. Fluck
Posts: n/a
Re: Custom Circuit
I'd assume so. The rule doesn't state anything about a box, as you said.
If I were you, I would go ahead and put the circuit in the box the circuit board, unless a team update is released that says otherwise.
Logically, the box would protect the circuit from damage during a match.
Keep an eye out for team updates.
This would be a good question to take to the FIRST team forums.
Unread 06-01-2003, 12:15
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
I think this is one to ask FIRST about. I did not see anything either and I was looking for the answer to that question specifically.
If I had to guess it would be that no special box is required. The rules this year have much more of a "if it isn't prohibited it is permitted" flavor. Last year the only sensors allowed outside the "box" were the banner sensors, the gyro, and switches. This year the field of allowed sensors is much wider and many would be useless if they had to be contained in a box.
But this does need a definite answer from FIRST one way or the other. Katie has been around long enough to realize that ALL electronics need protection in this competition. A box or shielding against damage will be important, but I don't think there is any requirement to use a particular means of protection this year. At least I couldn't find one.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 06-01-2003, 14:13
Under the inspection checklist, Electrical, is the following"Custom circuit must be totally contained in BUD box." I suspect that the part number or specifications will be on the additional hardware list.
Please note: If you are designing a custom circuit board, it would be wise to design it in such a way that removing it will not disable your robot. If you suspect a defect in the circuit you should be able to remove it and continue running. This is not a requirement, but a strong suggestion.
custom electronics Rickertsen2 Electrical 1 13-01-2003 00:15
circuit breaker archiver 2001 2 23-06-2002 23:18
So what's in YOUR Custom Circuit this year? kmcclary Technical Discussion 7 10-04-2002 12:20
Wiring custom toggle switches into operator interface DanL Electrical 9 13-02-2002 17:13
custom circuit boards ctartist236 Technical Discussion 5 08-01-2002 00:10
