#16
Re: Problems with tuning shooters using AM basketballs on Practice Field?
What I like best about the voltage control is that there is no tuning involved, set it once and don't worry about it after that. |
#17
We have a single 8" kit wheel driven by a single powerful FP motor. We seem to spend a lot of time waiting for the thing to settle down, we could probably shoot a few more baskets with the simple voltage algorithm. I posted a link to this thread on our team fb page, our programmer should see it.
Ironically today he's doing his science fair project report on the feedback speed control system ![]() |
#18
We're using 2x two 8" wheels on 1/2" shafts with AM hubs driven by AndyMark motors and Andymark 3.67:1 planetary gearboxes, and our PID is quite stable -- we fed both old and brand new balls through it and it was consistent except for once in a while... The compressibility of the ball didn't seem to influence the throw much.
...I hope that pans out! |
#19
Could you explain to someone ignorant why controlling with voltage is so much better than PID? I would think that you want constant rpms on the shooter wheels for maximum consistency. More success with a less sophisticated control system seems a little counter-intuitive to me...
#20
You're right...except that some of us seem to have built systems that are very difficult to get reliable speed control with. In that case, a consistent open loop system could work better.
#21
PID is a good solution but it is not magic. The software is only one part of the servo system. In this case one can tune the wheel to free rotate at a selected speed but not have enough gain to recover quickly when a ball slows it down. So one might try to raise the gain. But then the higher gain might create an under-damped or oscillating condition when there is no load. One approach is too build mechanical gain into the system by using stronger motors or storing energy in a flywheel etc. This gain would have much less phase delay and be more stable (I hope). HTH |
#22
I think this is definitely a case of "the best is the enemy of good enough." At least for my team this year. |
#23
interesting...we're a couple above you with closed loop! But I still think we should give open loop a try.
#24
Based on this thread, we are definitely gonna have both approaches ready to go! |
#25
For what it's worth I'd call our autonomous 70-80% reliable, with a large amount of our misses coming from shots spaced too close together where the second ball bounces off of the first. A delay between hybrid shots will be implemented for the Hartford regional. |
#26
We have a really long delay between shots, waiting for the shooter speed to adjust. Open loop could really speed up our shooting process, hopefully enough to get a few more shots off in teleop
#27
We also have a driver enabled adjustment button. Each click of the button decreases (or increases) the voltage applied to the shooter by 1/10th of a volt. This results in a decreased (increased) RPM of ~100. So if we find we are overshooting by 5 feet, the human shooter knows to decrease 3 clicks based on data collected during practices.
The problems that are often outside of our control (like ball squishy-ness) are the most valuable learning tools! Thanks, GDC! ![]() |
#28
This was a HUGE problem for Team 20 this past weekend at GSR; we went from a 60% shooter in practice to a 3% shooter. Our targetting was working, but we were over shooting the hoop by 4 to 5 feet every time. Come to competition with a plan in place to account for the difference, or you will be sorry.
#29
Are there any teams who attended a week 1 event who didn't have an issue with this?
