Go to Post Chairman's Award is not about building the robot. Every team builds a robot. - Retired Starman [more]
Unread 06-03-2012, 13:30
mikegrundvig mikegrundvig is offline
FRC #2410 (Metal Mustangs)
mikegrundvig is an unknown quantity at this point
What Shooter Design was Most Consistent
Sadly, our first competition of the year went very badly. Our vision system is accurately telling us the distance to the target in matches (+- a few inches most of the time) and we were able to control the RPM of our shooter very accurately as best we can tell. The PID loops appeared very reliable once tuned. Sadly, every shot was hugely variable so we were never able to really dial in the shooter itself. We have removed the entire shooter and hope to redo it before the next regional.
Our shooter has four 8" wheels, two on top, two on bottom. Each is run by a 550 motor to a max of about 2200 RPM. Honestly, far more shooting power than is practical. We had azimuth (horizontal rotation) as well as elevation (shot angle) in the system but we ended up pinning the elevation at around 60 degrees and just varied the RPM because we had mechanical issues with the elevation motors. Due to our rather obnoxious drive system that can't be easily changed we are going to have to retain the azimuth control to a limited degree as I doubt the robot can spin in place effectively
I believe our inconsistency came from our shooter having mechanical problems - feeding variability, lots of flex in the design, it had some bends in it due to crashes, far too much compression, etc. What I'd like to know is what other shooter designs were people using that are consistently accurate while still being simple enough for reliability.
At our regional the best teams appeared to be using a "hooded shooter" with two wheels on a single axle and limited compression. I'd love to see other solidly reliable ideas too.
As of right now, I think our best bet is a new shooter we can dial in to take advantage of our consistently good vision data.
Thanks!
-Mike
Unread 06-03-2012, 14:11
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: What Shooter Design was Most Consistent
Originally Posted by mikegrundvig View Post
I believe our inconsistency came from our shooter having mechanical problems - feeding variability, lots of flex in the design, it had some bends in it due to crashes, far too much compression, etc. ...
From our testing, this was the biggest culprit leading to shot variability. There were hardly any tweeks needed to the shooter after we got balls feeding consistently and made sure every guide/support/contact point for the ball was very rigid.
Our shooter is a similar configuration to yours, but with smaller 4" wheels (smaller wheels = smaller support structure needed = easier to make lightweight and stiff). We don't have any experience with the single wheeled shooters for this year, but I'm sure the above advice still applies.
Unread 06-03-2012, 14:20
Do you have an exit chute to guide the ball as it exits the spinning wheels ?
Or is the last thing the ball touches the wheels?
If the latter, that could be your inconsistency problem.
http://www.chiefdelphi.com/forums/sh...9&postcount=22
Unread 06-03-2012, 14:45
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Are you running your upper wheels and lower wheels at the same speed? If so, I would recommend running the upper wheels much slower than the lower wheels. If the two sets of wheels have the same linear speed, the ball will exit with no spin. That creates a lot of aerodynamic buffeting on the ball resulting in an erratic trajectory. Knuckle-ball pitchers have been using that to their advantage for years since erratic ball flight is great for fooling batters. However, erratic ball flight is not good for shooting baskets consitently.
A hooded shooter is easy to make, but it takes more than double the speed of a shooter with wheels on both sides of the ball.
Unread 06-03-2012, 15:53
Yeah, we knew it was a problem but didn't have the time to fix it. I believe it might be one of the bigger culprits as well.
Originally Posted by Ether
Do you have an exit chute to guide the ball as it exits the spinning wheels ? Or is the last thing the ball touches the wheels?
There is no exit chute currently. I believe we have far too much compression as well when I saw how little our competitors had. That video was very helpful.
Yes, we played with this extensively. Even with significant back spin we saw no increase in repeatability. When we knuckle-balled the shots intentionally we did see some lateral drift that went away when the ball was spinning.
Thanks much!
-Mike
Unread 06-03-2012, 16:01
pfreivald's Avatar
AKA: Patrick Freivald
Our shooter design is much like yours. What seems to work for us -- though it hasn't been tested in an actual competition yet, it showed great repeatability regardless of whether or not the ball was beat up or brand new in practice -- is compressing the heck out of the ball immediately before it is fed to the shooter.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 06-03-2012, 16:51
RB73 RB73 is offline
FRC #2866
RB73 is an unknown quantity at this point
Our shooter is very accurate. We have 2 six in wheels on the bottom and a curved plate on the top/back. We have the wheels powered by a CIMulator for the banebots motor (we max out around 4300 RPM). We read the RPM and get that within about a 50 RPM range of consistency before shooting and we use marks/objects on the field to line up. We average about 7/8 shots when lined up. We don't have any way of reading our distance or of changing the direction of the shot.
Unread 06-03-2012, 16:58
When you say "the" Banebots motor, which Banebots motor do you mean?
"get that within..." does the driver do this manually, or do you have a closed-loop controller?
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
So we had alomst the same design. What we changed to make it accurate was put a piece of tread across the bottom two wheels (ours were 6in). We also are only spinning the bottom wheels for a shot from the key. The top wheels are not moving at all. The bottom wheels are at full power, giving it the back spin. We are also using a 775 motor on a 4:1 reduction. Maybe make some of these changes and see how it works?! Our shooter was really consistent, we went undefeated this week and won our first regional ! Good luck with your shooter
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 06-03-2012, 17:02
FRC #2866
1. The RS-775 motor, here is a link to the gear box: http://banebots.com/pc/FIRST/S24K-C1-7
2. We have a visual display for the device operator. She can read the actual RPM of the shooter of use an "At Speed" box that will turn green when the shooter is at the desired speed.
Unread 06-03-2012, 17:16
FRC #2866
Also, If you are worrying about the single drive shooter being too weak, stop worrying. Our team, 2866, was making 3 pointers from the coopetition bridge at the DC 2012 Play Day/Scrimmage.
Unread 06-03-2012, 17:42
does the driver adjust the speed manually, or do you have a closed-loop controller do that?
Unread 06-03-2012, 17:47
FRC #2866
We have preset speeds for the shooter. The device operator chooses what speed the shooter needs to be for certain locations and then shoots the ball when the RPM is stable.
Unread 06-03-2012, 17:53
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Thank you for the help. We'll try some of the advice suggested to us tonight (We took the shooter and the necessary electronics as our 30lbs off the robot.
Next question would be what you think would be the best approach to analytical testing? Some of our programmers are getting overwhelmed with exactly what to test. Ideally, we would like to pin it down to one independent variable (Whether it be the top rpm and change the bottom rpm to the accuracy, or set both rpms and find the corresponding distance, or something of that sort) and test from there.
Furthermore, how much of an exit chute would be necessary for the accuracy to improve? As our robot weighed in at 120 flat, I do not believe we would be able to add much to the chute without significantly reducing something elsewhere (Which, at the moment, we are unable to do because of the fact the robot is bagged)
When we attempted to create an entrance chute to reduce the feeding variability, it simply resulted in a drastic reduction of range (Down to less than 5 feet)
Finally, would it be worth it to scrap the quadwheel shooter all together and design a compression hood shooter in time for Oklahoma Regional (March 29th-31st)
Academic Student (Forever)
Unread 06-03-2012, 18:11
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Sup buddy?
I suggest you re-evaluate what tasks you need the shooter to accomplish. You may find some of the early season assumptions are not true, or not necessary.
If you decide a rebuild is in order, You have time. AND:
Please use smaller wheels . My vote is a single axle shooter made with something that "centers" the balls nicely and a very high shot angle. Mix in a nice feeder that puts the balls in with consistent spin, and I like it.
If you need to bounce an idea off of someone/something, feel free to give me a call (skype design sesh tonight? ). I have far too much to list in text and far to little time to do so.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
