Re: Team update 3/6/2012
Potentially addressing, you mean. It'll be interesting to see how well this modification performs at Week 2 events. It might make things worse by causing balls to collect right at the edge of the bridge where they're hardest to squish and most likely to cause difficulties. The only advantage is that they'll be slightly easier to remove there.
I noticed that they didn't address 118's hanging mechanism at all. I know the head ref at Alamo presented a statement but the GDC can't expect everyone to have heard that.
The GDC will never state that XXX's robot is illegal to all the other teams. They state the rules, and will evaluate them on a case by case basis at the events.
I'm glad to see this change after competing in week 1. Balls under the bridge definitely added challenge to the game play but it was a challenge we all knew was coming. I think FIRST has done a great job with the bridges as there is only so much they can simulate (after competing at a FIRST scrimmage balls and bridges weren't a noticeable issue because bridge play was not as common) but they did a great job with the ramps to keep balls from getting stuck far back. This change should really improve the huge number of balls that don't have enough inertia to get stuck and come to rest at the bottom of the lexan plate just enough to interfere with the bridge.
Thanks FIRST! |
#7
I might be mistaken, but are the drawings conflicting in terms of how the ball ramp is mounted below the bridge? If you look at drawing GE-12017, compare the way the ball ramp is mounted in sheet 1 & 2. Which one is correct or am I not seeing something?
#8
Also, for anyone who doesn't want to go through the hassle of opening up the field drawings, here is a screen shot of the drawing that shows the relevant changes. (Please excuse the size) ![]() |
#9
This will help some, but the polycarbonate just isn't rigid enough and will continue to sag down to the edge of the bridge. What would really help is some edge strip to hold the polycarbonate straight. Dr. Bob Chairman's Award is not about building the robot. Every team builds a robot. |
#10
Glad to see they made a change. In elimination matches, alliances were losing because there happened to be balls under their ramps and they could not get on; either intentionally placed by the opposing alliance, or balls just happened to roll under.
#11
How does the ramp get steeper when the bridge is pushed down? It looks to me like the ramp is mounted to non-moving parts.
#13
I believe Starman is referring to the ball deflector when talks about the "ramp." That is, with this update, the ball deflector has been rotated so that it's at a steeper angle with respect to the floor.
EDIT: Er, nevermind... you already understood that. He's saying that when the bridge is pushed down, the underside of the bridge contacts the ball deflector and pushes it down as well. Last edited by Nate Laverdure : 07-03-2012 at 13:34. |
#14
My point is just that all the improvement of the new assembly comes from it being steeper while the bridge is up, hopefully getting balls out before the bridge comes down. |
#15
