Go to Post Failure is in my eyes, the key to success. If you can deal with failure, look it in the eye, and conquer it, the hard stuff won't really intimidate you any more...and you can only get better. - Andy Grady [more]
Unread 06-03-2012, 18:05
Triapod Triapod is offline
Triapod is an unknown quantity at this point
cRIO Status Light
After reimaging the CRIO to the newest version, we are unable to communicate via ping or CRIO imaging tool. The yellow status light blinks. Anyone know what is wrong?
Thanks
Unread 06-03-2012, 18:24
Re: cRIO Status Light
What's the sequence of blinks?
Unread 06-03-2012, 20:09
I'm guessing the left column is flashing every 1,2,3, or 4 seconds? What would be flashing continuously then?
Unread 06-03-2012, 20:18
The flash sequence would go something like:
flash, flash, flash - pause off (repeat)
Unread 07-03-2012, 15:00
It flashes once then stops and repeats
Unread 07-03-2012, 15:27
The image went awry or is otherwise corrupted then.
You'll need to set the Safe Mode switch, reboot the cRIO and try with the Imaging Tool again.
