Re: Team update 3/6/2012
I might be mistaken, but are the drawings conflicting in terms of how the ball ramp is mounted below the bridge? If you look at drawing GE-12017, compare the way the ball ramp is mounted in sheet 1 & 2. Which one is correct or am I not seeing something?
Also, for anyone who doesn't want to go through the hassle of opening up the field drawings, here is a screen shot of the drawing that shows the relevant changes. (Please excuse the size) ![]() |
This will help some, but the polycarbonate just isn't rigid enough and will continue to sag down to the edge of the bridge. What would really help is some edge strip to hold the polycarbonate straight. Dr. Bob Chairman's Award is not about building the robot. Every team builds a robot. |
Glad to see they made a change. In elimination matches, alliances were losing because there happened to be balls under their ramps and they could not get on; either intentionally placed by the opposing alliance, or balls just happened to roll under.
How does the ramp get steeper when the bridge is pushed down? It looks to me like the ramp is mounted to non-moving parts.
#7
I believe Starman is referring to the ball deflector when talks about the "ramp." That is, with this update, the ball deflector has been rotated so that it's at a steeper angle with respect to the floor.
EDIT: Er, nevermind... you already understood that. He's saying that when the bridge is pushed down, the underside of the bridge contacts the ball deflector and pushes it down as well. Last edited by Nate Laverdure : 07-03-2012 at 13:34. |
#8
My point is just that all the improvement of the new assembly comes from it being steeper while the bridge is up, hopefully getting balls out before the bridge comes down. |
#9
Ah, that makes more sense. Thanks!
#11
I think it would be very unfair to teams like mine who solved the original problem but would run a serious risk of 'damage to playing field' penalties if the field element design was changed radically. We took the mentality that it was just another challenge to overcome and another feature to set our robot apart. I'll admit I'm a little disappointed with the change because it takes an advantage away from teams like ours that worked hard to have that extra capability. /mild rant |
#12
It might be that some fields (and even different bridges on the same field) were setup slightly differently and therefore behaved differently and that you and I merely have different observations. |
#14
Interesting. I noticed the taped-down lexan at the Nashua Week 0 and GSR Week 1. Clearly not all fields were setup the same.
