Go to Post The code is hopefully pretty self-documenting, but I haven't had time to comment it (kinda trying to build a robot at the moment). - RyanCahoon [more]
Unread 06-03-2012, 17:55
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Team update 3/6/2012
http://frc-manual.usfirst.org/TeamUpdates/0
Week 1 Observations and Reactions
The 2012 FRC events have begun, and Week 1 was a great testament to the FRC community’s ability to respond to the challenge. The events went well, and we hope that the Week 1 participants had fun and valuable experiences. Congratulations to Week 1 teams and volunteers for contributing to Week 1 successes.
That said FRC Staff and Volunteers have reviewed issues and opportunities that manifested in Week 1 and, in the spirit of continuous improvement, share the major ones, and their reaction plans, below.
The Arena
At some events, there were more trapped Basketballs toward the lip of the Bridges than originally expected. To address the issue, we have made a minor change to the way the ball deflectors mount under the bridge. We expect this will greatly reduce, but not necessarily eliminate, the instances of Basketballs trapped under the Bridges. These modifications effectively leave the dynamics of the Bridge unchanged. For details, please see the modified drawings GE-12017 and GE-12064.
The Robot
Inspection
Week 1 Inspectors have shared the three most frequent issues at Week 1 events. We share them below as a heads up for future competitions.
Bumper construction and placement
Robots had Bumpers shorter than 8”, measured from the vertices of the Frame Perimeter. A ‘Bumper’ is made up of the plywood backing, pool noodles, cloth covering and fasteners. Soft fill at the ends of Bumpers does not contribute to minimum Bumper length. Reference Rules [R27], [R28] and [R31].
Bumper numbering
Robots had their team numbers displayed in more than 4 locations on their Bumpers. Reference Rule [R35].
Robots had numbers that were not white or outlined in white, or not properly sized. Reference Rule [R35].
Robots had team numbers split between Bumper segments. Reference Rule [R35] and GDC Q&A answers related to this rule.
Motors
Robots used motors that are not permitted, or modified motors in ways that are not permitted. Reference Rules [R48] and [R49].
DLink Wireless Bridge – Hardware Version
DLink has released a new version of the DAP-1522 wireless bridge hardware used on the Robots. The new hardware revision, Rev B, is legal for use in FRC events; however, is not programmable by the Radio Programming Kiosk at events.
If a team has a DAP1522 Rev B (which would only be if they purchased a wireless bridge on their own, all bridges shipped in Kits are Rev A), they will need to retrieve their WPA key from the FTA at the beginning of the event and configure their bridge manually. Due to this inconvenience and opportunity for error, FRC strongly recommends that teams use the Rev A version of the hardware if possible.
A user can easily tell the difference between the Rev A and Rev B hardware platforms. In addition to being noted on the box and the back of the device on a sticker, the front of the bridge is also visibly different. In the image below, the Rev B is the upper radio, with the Rev A below it.
General
The official Android App for the 2012 FRC Q&A system is now available.
Good luck to all teams in Week 2!
Glad to see that FIRST is addressing the balls trapped under bridges.
Unread 06-03-2012, 18:08
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Team update 3/6/2012
Potentially addressing, you mean. It'll be interesting to see how well this modification performs at Week 2 events. It might make things worse by causing balls to collect right at the edge of the bridge where they're hardest to squish and most likely to cause difficulties. The only advantage is that they'll be slightly easier to remove there.
Unread 06-03-2012, 18:10
pfreivald's Avatar
AKA: Patrick Freivald
That's good for us, I guess -- but bad for teams without a deployable ball intake.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 06-03-2012, 18:13
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
They are certainly addressing the issue. They are only potentially mitigating or rectifying the issue.
Unread 06-03-2012, 18:21
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
I noticed that they didn't address 118's hanging mechanism at all. I know the head ref at Alamo presented a statement but the GDC can't expect everyone to have heard that.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 06-03-2012, 18:25
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
After looking at the modified field drawings, I definitely think this will improve things during week 2. The angle of the polycarbonate piece is greatly increased. Hopefully balls will, at worst, remain at the edge of the polycarbonate, allowing teams to simply push the balls out of the way with their drive train or intake them into their robot. Teams seemed to have the most problems during week 1 when the balls would escape the reach of most team's intakes or appendages under the bridge.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 06-03-2012, 18:33
GoSparx's Avatar
GoSparx GoSparx is offline
AKA: Big D
FRC #1126 (SparX)
GoSparx is just really niceGoSparx is just really niceGoSparx is just really niceGoSparx is just really niceGoSparx is just really nice
No matter what, it seems, FIRST can never appease the masses.......
"Winning is an Outcome"
2003-2008 Match record 152-81-1
Trips to Einstein - 2 (04' + 06")
'03, '04, '08 Buckeye Champs, '07 Finalists
'06 Finger Lakes Champs, '08 Finalists
'06 Galileo Division Champs
'04 Newton Division Champs
'08 Buckeye Motorola Quality Award
'07 Buckeye General Motors Industrial Design Award
'06, '07 Finger Lakes Rockwell Automation Innovation in Control Award
'05 Buckeye RadioShack Inovation in Control award
2-2009 J+J Gracious Professionalism Awards(FLR+GTR) & Xerox Creativity Award(GTR)
Unread 06-03-2012, 18:54
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Was there really a problem with illegal motors being used? I know there was some confusion about not being able to use 540s on our team, but I would expect that teams would understand the motor restrictions...
-Plutarch
Unread 06-03-2012, 18:56
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
The GDC will never state that XXX's robot is illegal to all the other teams. They state the rules, and will evaluate them on a case by case basis at the events.
Unread 06-03-2012, 19:09
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
I'm glad to see this change after competing in week 1. Balls under the bridge definitely added challenge to the game play but it was a challenge we all knew was coming. I think FIRST has done a great job with the bridges as there is only so much they can simulate (after competing at a FIRST scrimmage balls and bridges weren't a noticeable issue because bridge play was not as common) but they did a great job with the ramps to keep balls from getting stuck far back. This change should really improve the huge number of balls that don't have enough inertia to get stuck and come to rest at the bottom of the lexan plate just enough to interfere with the bridge.
Thanks FIRST!
1058 PVC Pirates 2016 - xxxx
Unread 06-03-2012, 19:47
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
I might be mistaken, but are the drawings conflicting in terms of how the ball ramp is mounted below the bridge? If you look at drawing GE-12017, compare the way the ball ramp is mounted in sheet 1 & 2. Which one is correct or am I not seeing something?
Unread 06-03-2012, 20:01
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I noticed the same thing. If you look at the Rev Level, Sheet 1 is Rev A while sheets 2, 3 and 4 remain at their base revision. In this case Sheet 1 would take precedent over the others.
Also, for anyone who doesn't want to go through the hassle of opening up the field drawings, here is a screen shot of the drawing that shows the relevant changes. (Please excuse the size)
-Dustin Benedict
Unread 06-03-2012, 20:41
Marc S.'s Avatar
AKA: Adversity
I wasn't looking for first to say that team XXX is illegal, I was looking for the rule update/clarification that made the hanging mechanism (like the one on 118) illegal.
Unread 06-03-2012, 21:06
ChrisH ChrisH is online now
Generally Useless
FRC #0330 (Beach 'Bots)
The change is only shown on Sheet 1. They probably just forgot to update the view on Sheet 2. Easy to do when there are 123 sheets just for the game specific elements and you have less than a day to find a fix for a major problem and get it approved, documented, and published.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 06-03-2012, 21:26
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant future
The change makes two improvements in the ramp. First, the polycarbonate ramp has been turned over and the aluminum angle, which was below the ramp has been removed. This makes the angle of the ramp steeper and it will bet even steeper when the bridge is pushed down. Look at GE-12064 to see that the aluminum angle has been removed. This drawing shows the polycarbonate upside down, guess FIRST didn't want to take time to flip it. GE-12017 page 1 shows the new orientation of the ramp. As before, the ramp is pulled up tight under the bridge.
This will help some, but the polycarbonate just isn't rigid enough and will continue to sag down to the edge of the bridge. What would really help is some edge strip to hold the polycarbonate straight.
Dr. Bob
Chairman's Award is not about building the robot. Every team builds a robot.
